Old 06-24-2009, 10:44 PM   #16
SWTour's Avatar
I have a tc4 with a sphere comp esc and a 4.5 motor what king of lipo how many mah and how many c is good. I have a venom pro charger
Instead of just throwing a bunch of dumb numbers and mfgs around to you...
How about MORE information on what you are racing (type of track) or if you are just bashing.
The 4.5 motor is going to most likely get the ESC very hot...you'll want to use HEAVY good strand wire on your esc, and keep it as short as possible...(Both to the battery and to the motor)
The TQ wire is probably the best available.
USE a heat sink on both the motor and speed control if possible (especially if you are bashing more than racing)
Use a SINTERED ROTOR in the motor
The "C" Rating can be important especially with the low turn motors. They pull a lot of amps, and that's where a higher "C" rated battery really shines.
The higher the "C" rating, the better the battery voltage holds its load.
Also, make sure the battery fits in your tray.
Some of the higher "C" rated packs, are also larger in size (usually taller)
There are lots of GOOD Lipos on the market.
You can shop by PRICE for your PRICE range, or by "C" Rating and mAh rating if you are looking for performance.
THUNDERPOWER has probably THE Best performance packs on the market right now, but there are lots of good choices....but it would be easier to get a good true reccomendation if people know what you are planning to do with it!~
Joe Myers
R/C Racing since 1985 ~ Santa Maria, CA (Central Coast)
2001-2012 - South-West Tour R/C Oval Series - R.I.P.
...will the SWT be revived? Time will tell, but we ARE returning to the VELODROME in 2016
SWTour is offline   Reply With Quote
Old 06-25-2009, 07:31 AM   #17
Trader Rating: 29 (100%+)
Default Lipos
IMHO I would buy the Thunderpower 40c. I've owned 20c 5000mah, 35c 5000mah and now the Thunderpower 40c and there is a difference even between 35c and 40c. I've heard the Smc 40c packs are good to but I haven't tried one.
RSTECH is offline   Reply With Quote
Old 06-25-2009, 01:21 PM   #18
stitchy's Avatar
Buy the highest mah and C you can afford, and take the battery out of the equation.
Congratulations, you have one less excuse.
stitchy is offline   Reply With Quote
Old 06-25-2009, 08:13 PM   #19
i got a thunder power 5000 mah 40c
wichol98 is offline   Reply With Quote
SEO by vBSEO 3.5.0
