Corally RDX Droop >
Corally RDX Droop
Corally RDX Droop
Old 06-23-2009, 05:47 PM
jhock's Avatar
Default Corally RDX Droop
What are you guys using or have used on the RDX for Droop settings? Asphalt and Carpet Rubber tires?
jhock is offline
Old 06-23-2009, 06:09 PM
Cpt.America's Avatar
Trader Rating: 52 (100%+)
There aren't really "Settings" for droop. Droop is how far the chassis lifts before the tires leave the ground, RTR (ready to race). It is a direct result of downstop settings and ride height.
Cpt.America is offline
Old 06-23-2009, 06:30 PM
jhock's Avatar
I know, just lookin for everyones settings on there RDX
jhock is offline
Old 06-23-2009, 07:12 PM
Mark506's Avatar
Trader Rating: 42 (100%+)
ah I just usually eyeball it, but usually more in the front. If i can remeber, I think maybe like 4 mm or something close to that in the front.
Mark506 is offline
Old 06-23-2009, 10:04 PM
Trader Rating: 16 (100%+)
Using an Associated droop gauge, I usually start with 5mm front and rear for carpet and asphalt.
Still Bill is offline
Old 06-24-2009, 07:20 AM
xevias's Avatar
For VTA and RCGT, I have 6mm ride height with 3mm droop above ride height front and rear, for both asphault and carpet.
I then make 1/16 of a turn adjustments at the track depending on traction and performance.
I always stay within 2-4mm of droop front and rear.
xevias is offline
