Old 06-14-2009, 12:18 AM   #1
05forfun's Avatar
Trader Rating: 81 (100%+)
Default Novak GTB and LRP TC drag brake problem
I tried to setup drag brake for these two ESCs and I found out the intensity is very different. The min level in LRP is much stronger than max level in GTB. I thought it may be motor's problem, so I swapped them, but still the same. By the way I used brushless motors (Trinity Duo 17.5 and Novak SS17.5)in two different cars (TC3 and TA05R). I will try to put them in different cars to see if there is any difference. But did anyone discover this problem? Is it the reason some people like one over the other? or I have setup the ESC wrong?
05forfun is offline   Reply With Quote
Old 06-14-2009, 02:10 AM   #2
sudhar93's Avatar
Send a message via MSN to sudhar93
Did you do the esc radio set up properly?Or are you using two different radios on both esc.
This esc are mostly use for touring so the drag brake too much can burn ur motor.So i cant help you much as normally we use zero drag in our place here.
Tamiya-LRP - Team Powers - RIDE -Sorex -Protoform - Sweep -Futaba - GQ
-------------Car Needs Minor Tuning, Driver Needs Major Tuning -------------
sudhar93 is offline   Reply With Quote
Old 06-14-2009, 12:27 PM   #3
Scott B's Avatar
Trader Rating: 42 (100%+)
I don't think you set it up wrong. I think its just two different esc's from two different manufacture's. One just designed more breaking into there speedo then the other.
Mugen Racing, Matrix Racing Tires, Sweep Racing Tires, Novarossi, R1 Wurks...
"When I want the truth I go to the internet because that's the magical place where no one lies"...
"On-road is racing.. off-road is 50% competitive jumping and 50% crash avoidance"...
Scott B is offline   Reply With Quote
Old 06-14-2009, 01:02 PM   #4
05forfun's Avatar
I hope so and that is what I thought about these two ESCs. I will try to swap these two between two cars and see if car's design has anything about this issue. Now GTB is in TC3 with Novak 17.5 and LRP is in TA05R with Trinity Duo 17.5, different drivetrain but I am expecting similar result.
Old 12-19-2009, 09:46 PM   #5
z50king's Avatar
Send a message via AIM to z50king
I run dirt and the brake on my GTB esc is very weak
anyone else? my friend also has weak brake on his gtb
Eric #187. Associated, Tekin, West Coast RC Raceway
t4, mod t4, sc10b, lcc, scx10
z50king is offline   Reply With Quote
Old 12-20-2009, 04:37 AM   #6
V_28's Avatar
My GTB is a bit soft too even though I have the brakes on max...thought it isn't so soft that the car rolls on when full brakes are applied, just it takes a few milliseconds to really hault. Just had to change my driving style of turns though and it is ok. I thought it was something to do with my GTB but seems like brakes are not its strongest point. Still love the ESC though.
V_28 is offline   Reply With Quote
Old 12-20-2009, 07:11 PM   #7
Toh WL's Avatar
I am using Novak GTB 4.5T last time. The drag brake sucks hence the car slides. However I change the ori black rotor to sintered as recommended by Novak. Hence the drag brake does improves.
Toh WL is offline   Reply With Quote
lrp brushless esc raceblast Electric On-Road 840 04-02-2012 04:45 PM
SEO by vBSEO 3.5.0
