Corally RDX Phi 09 >
Corally RDX Phi 09
Corally RDX Phi 09
Old 11-09-2009, 04:30 PM
  #331
Jerzy JayRO's Avatar
Trader Rating: 38 (98%+)
[QUOTE=Isaac;6573304]I actually have an 88 spur and 35 pinion. Straight is about 110 feet long. Tekin RS and Duo2.
[QUOTE]
HEY ISAAC, WHAT KINDA FINAL DRIVE YOU GOT 1.77 OR 2.0?? WITH THE TEKIN ANY IDEA ABOUT HOW MUCH MOTOR TIMING AND BOOST YOU HAVE? WE ARE RUNNING ON AN TRACK ABOUT 100 X 40. STILL NEW TO TOURING CAR AND LEARNING EVERYDAY ABOUT SET UP'S.... ANY HELP IS A PLUS
THANKS
JAYRO
Jerzy JayRO is offline
Old 11-09-2009, 04:40 PM
  #332
Originally Posted by The Teacher
Jeff Cuffs, what's the hot lick setup on carpet with foam...? C'mon son!!! I know you got that fire....
What up teach. Ill post tomorrow my foam and rubber tire setups tomorrow. How you been? When u gunna make it to horsham?
Jeff Cuffs is offline
Old 11-09-2009, 04:42 PM
  #333
A Ilievski's Avatar
Trader Rating: 39 (100%+)
[QUOTE=Jerzy JayRO;6585067][QUOTE=Isaac;6573304]I actually have an 88 spur and 35 pinion. Straight is about 110 feet long. Tekin RS and Duo2.
THANKS
JAYRO
Try full turbo and about 20 boost. Play and add more time delay as its needed. And about 10 degress on the can.
A Ilievski is offline
Old 11-09-2009, 05:46 PM
  #334
Isaac's Avatar
I'm running the 2.0 My final drive ratio is between 5.1 and 5.5. Zero on the motor, full turbo and timing. I come off cool like 140 or so on the the present layout. Should have finished 4th in the A last week but friend and arch rival The Teacher kind of passed me using my passenger side door to get by.
THANKS
JAYRO
Isaac is offline
Old 11-09-2009, 06:22 PM
  #335
THANKS ISACC
Old 11-10-2009, 12:26 PM
  #336
The Teacher's Avatar
Trader Rating: 62 (100%+)
Jeff Cuffs, post them...I need both!!!! Me and BHess will be up to Horsham soon.......soon as I can get him off the couch Heard the track is nice, glad to see you guys back up and running...
The Teacher is offline
Old 11-14-2009, 03:57 PM
  #337
WHAT BODIES ARE YOU GUYS RUNNING ON CARPET?
Old 11-14-2009, 09:26 PM
  #338
Super Moderator
J.Whiting's Avatar
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 63 (100%+)
i have been running several different bodies. what i like is. 1/10 RTB GBS (Rubber Tire) - Clear Body - #10224
mazda 6, mazda speed 6, ltc-r rubber tire body. all work very well depends on how much traction you have. mazda 6 gives leat amount of traction. then speed 6 and ltc-r medium traction. and the parma body gives the most grip. have done testing on all the bodies back to back. jeremy
J.Whiting is offline
Old 11-17-2009, 01:24 AM
  #339
Hi guys,
I've just order a lipo spec phi 09.. will be a bit of an upgrade from my RDX
I just had a question about running a diff in the front. I see you have to turn the bearing holders around and I think I read earlier that people were having the bearings fall out, so do I've ordered the bearing clips, but do they fit into the plastic bearing holders or do I need to get the alloy ones?
cheers
kiwirevo is offline
Old 11-17-2009, 03:54 AM
  #340
Super Moderator
J.Whiting's Avatar
Originally Posted by kiwirevo
Hi guys,
cheers
correct if you run a spool or diff you need to get the alloy bearing holders and the clips. there is no groove in the plastic holders to seat the clips. in my car i have the alloy up front and the plastic in the rear. i went with the spool up front and picked up .2 sec. a lap over a one-way. are you running rubber or foam tires?? why a diff over a one-way or spool?? i posted my current setup a page or two back. car is fast and easy to drive. spool or one-way work very well in that setup. jeremy
Old 11-17-2009, 06:43 PM
  #341
In NZ we run foams on tarmac so picking a set is hard, I find the spool is just as good but increases tyre wear, so I tend to run a diff on club days.
What are the carpet spec phi09s coming with then, do they have the alloy holders?
even more expense, I spend more than the price of the car on parts already (tuning and spares)
kiwirevo is offline
Old 11-17-2009, 07:05 PM
  #342
Super Moderator
J.Whiting's Avatar
car comes with plastic holders... get the u.s version it comes with a diff and thicker chassis for the foam tires. jeremy
Old 11-18-2009, 01:38 AM
  #343
Hi guys can anyone help me with a rough Pin/Spur for 17.5 racing please 48dpi.
PHI2 is offline
Old 11-18-2009, 01:47 AM
  #344
So how do the bearings stay in with a diff in there on the US spec ones?
kiwirevo is offline
Old 11-18-2009, 05:25 AM
  #345
crabboy's Avatar
Trader Rating: 58 (98%+)
The bearings dont hold in when running a spool or diff, they are pushed in and will fall out first run.
I put a drop of CA glue in the holder and then pushed the bearings in and that seems to have worked well.
Rhys
crabboy is offline
