Stock Motor Survey!!!
I thought I join the survey bandwagon.....
I like to know your favourite stock motors.... and why.... like:
Motor: whatever make
For: revs like hell
Against: no torque!!!
Remark: Good on long tracks with long straights and not much infield...
Rebuilds: often / not often etc...
I am only talking about straight out of the packet ones, but you can also recommend any simple upgrades like changing brushes or springs to improve its performance.... we can call it
Best Upgrade:
If you dont want to give the game away then we can leave that out...
Of course you can mention several of them.... I just like to find out more on the general characteristics of what is available out there....
For: revs like hell
Best Upgrade:
Motor - trinity p2k.
only mod - integy x-pattern 4%silver brushes - these brushes improved punch a lot.
Characteristics - people at one club think I'm running a mod (occasionally) (but at another club i get blown away).
Motor - GM3
Brushes - Orion pro stock
springs - red / green
Brushes make a big difference to performance over standard brushes.
Keeps up with Sosidge down the straight and very punchy on the infield: sneaky:
Trying out a Reedy Rage this week fitted with Reedy 768 brushes, Trinity red / green springs.
Let you know how this compares.
Yorkie
Yorkie
i like the trinity gm3....i use reedy 766 brushes, with a cavity, and i use either green or red springs, depending on the track layout....
I have 2 favs.
P2K2
4499 Trinity Brushes
Purple/red springs
MVP
.140 4499 Trinity Brushes, like them better than the 766.
Red/Green or Purple/Red springs depending on track
At the moment the P2K2 is the faster motor of the two.
P2K2
Purple/red springs
MVP
Can anyone tell me what the different spring rates are for the brushes i.e softest to hardest.
What effect does running stiffer or softer springs on the + or - sides?
Yorkie
Yorkie
Trips.... do you lathe your comm at every race? how many runs do you get between each cut?
Currently I am using 2 motors, a standard P2K Pro and BRM stock... I am trying new brushes on the P2KPro soon. The BRM is a very torquey motor and it really starts to shine after having 2 packs thru it.... but I find the hard silver (180 degrees or so ) springs maybe a little tough on the comm, so I am trying to use RED/GREEN combo or Purple springs and see if it makes it any different...
Yorkie
Yorkie
Yorkie... On the Team Orion site they have a range of springs which are listed in degrees.... the wider, the stronger... much easier then remembering colours...
WIth Trinity... I only know green is softer than red which is softer than purple, the hardest I will go except for the one cam with my BRM....
From what I have gathered.... the tighter the spring, you get less RPM but more torque... but either too light or hard you will get more comm wear....Light springs = more bounce and hard springs = more grind!!! can't win.....
Thanks Guys,
That's a great help. I'm getting to the stage where I can tell a big diference between different brush an spring combos.
I looks like red / green springs are the favourite and brushes seem to be down to personal choice.
Yorkie
Yorkie
I relpace the brushes if they look discolored or if they are getting short. Otherwise I just clean them up and re-serrate and break them in again.
Trips
Good advice Trips.... I have been trying a new motor and I had the third runs on my second to about sixth= seven run... and on my ninth and tenth run I noticed the motor feels a bit slower.... so I guess after runnind in I get max performance for about 4 runs before it starts to deteriorate....
Looks like i need to import a Team Orion laths as it seems no one got them here... and others are 40% more $$$
Motor: P2k, black springs Trininty 4500 brushes
For: track spec motor, good balance of tourque and revs
Against: could rev a little higher I think
Remarks: good motor, I like spec class because it levels the playing feild
Rebulds: Whenever someone I know whips out thier comm lathe...
