Old 12-01-2009, 07:46 PM   #121
abailey21's Avatar
Trader Rating: 35 (100%+)
Originally Posted by hanulec View Post
haha - are you going to be at the birds? let's see what the upcoming Birds class structure is and then we will find u a car. Atomic appears to be out of stock overseas right now.
you actually need to ask if i'm gonna be there? the hotel is 40 miles from my house...BTW can I crash in your room lmao
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 12-02-2009, 10:11 PM   #122
Default Atomic VM-II article from Hong Kong
Attached are pages of most recently published article about VM-II from Hong Kong. I will provide the translation in PDF subsequently. The Forum rejected the PDF due to size limit; I need to break it up.
Atomic VM2 M-Class Chassis-atomic-vm-ii-6-.jpg   Atomic VM2 M-Class Chassis-atomic-vm-ii-6-2.jpg   Atomic VM2 M-Class Chassis-atomic-vm-ii-6-3.jpg   Atomic VM2 M-Class Chassis-atomic-vm-ii-6-4.jpg
Atomic-USA is offline   Reply With Quote
Old 12-03-2009, 10:08 PM   #123
Spec-R is the company that makes a high quality CV universal for the VM-II. According to the video it minimizes vibration for the inner wheel especially during extreme turning angle:
Also for VM-II
http://www.spec-r.com/specr/
VIDEO
And...The translation for the Atomic VM II article is here: CLICK for PDF
Dealer Xing is offline   Reply With Quote
Old 12-12-2009, 07:55 PM   #124
Hello racers! We are excited to be hosting the 'Invitational M-class expo' presented by Atomic at the upcoming Snowbird Nationals. Check out the race flyer with all the great details and prizes for racers:
http://www.snowbirdnationals.com/sno...AtomicExpo.jpg
Already have our 1st driver entered! Have fun!
RCThunder is offline   Reply With Quote
Old 12-12-2009, 09:49 PM   #125
Trader Rating: 88 (100%+)
Default Servo
What type of servo is required for this car? It looks like a low profile standard servo but I can't tell for sure. Will 1/12th servos work?
tcdrvr2 is offline   Reply With Quote
Old 12-12-2009, 11:04 PM   #126
hotdognobun's Avatar
Trader Rating: 31 (100%+)
you can use any standard servo. low profile is always good for needed extra space to lay your esc and reciever. After all the electronics/battery a 1/12 servo might not handle all the force from high speed turning.
hotdognobun is offline   Reply With Quote
Old 12-24-2009, 10:27 PM   #127
Default Tires and spares
I've ordered my VM-II but need some advice on tires and inserts for carpet racing. I was thinking the Atomic 32's with the medium insert as that would be closest to Jaco Blues I think but any adviece would be appreciated. Also I've ordered Arms, C-Hubs, knuckles, sway bars and a spur, anything else that I should get going into a race?
Old 12-25-2009, 09:06 AM   #128
These cars look like a ton of fun. I have a couple of questions I was hoping someone that actually had one could answer.
1.) what size and pitch spur gear does the kit use?
2.) What is a good pinion to start with, with the 13.5 brushless motor
3.) best tires for carpet?
To anyone that actually knows, THANK YOU.
Ginsu is offline   Reply With Quote
Old 12-25-2009, 07:17 PM   #129
1. it is a 64p 100t 1.7final drive
2. http://www.comeseethis.com/gearing/gearing.htm
3. I always use soft w/medium foam inside
Old 12-25-2009, 07:30 PM   #130
i would buy the ball diff for the front! If you are using lipo I strongly recommend softer springs. I am using tamiya mini shocks and ball diff frt/bck
Old 12-25-2009, 07:33 PM   #131
Thank you very much.
Old 12-28-2009, 08:49 AM   #132
Should be good racing at the 'birds! Still openings for the M-class!! Killer prizes for the racers in it...
Old 12-28-2009, 11:02 AM   #133
billjacobs's Avatar
Trader Rating: 51 (100%+)
Default atomic
The stock rear diff is steel and is heavy. The xray t2 ball diffs fit into the vm2. Although new they are expensive, if you find them used for about $25-$30, they are better than the stock diffs. The xray 34t composite spool also fits the vm2. From my experience, it has a lot less outdrive wobble than the stock spool.
The vm2 shocks are copies of the trf shocks but are not anywhere near as smooth. I used tamiya teflon pistons and bladders in the vm2 shocks and they are better, but still not as good as the trf shocks.
Atomic also makes a lipo battery box for the xray t2 series that fits into the vm2 (you don't use the plastic end pieces.) Makes putting batteries in much easier and it protects the battery.
billjacobs is offline   Reply With Quote
Old 12-28-2009, 08:35 PM   #134
You are my hero! That is the tips of the year for me! Thx x2.
Old 12-28-2009, 08:42 PM   #135
hello again my hero! lol. Nexusracing.com sells xray parts so I'm gonna try the T2 set up BUT is there anything I need to know cause Xray has several Different T2's (t2,t2r,t2007,t2008,t2009) would any do? Thx again
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
M Chassis Conversion Kit For TT01-E & TT01 evanwest94 Electric On-Road 99 11-10-2013 02:18 AM
Electric on road dameetz Brunei R/C Racers 195 05-13-2011 08:42 PM
1/12 Touring Cars TommyBlazin Electric On-Road 20 05-07-2009 11:00 AM
SEO by vBSEO 3.5.0
