Old 08-19-2009, 11:46 PM   #76
Originally Posted by HKSRC View Post
If you are in San Fran looking for VMII, you can also contact Leo. BTW.
I talked to Leo and he told me talk to you Mr. M.
Sydewynder is offline   Reply With Quote
Old 08-25-2009, 02:19 AM   #77
KandyRedCoi's Avatar
Send a message via AIM to KandyRedCoi
subscribed
gonna wait and see how Chad's Atomic fares against our ABC cars (and also some HPI cr's)
https://www.facebook.com/ctdesigns09
KandyRedCoi is offline   Reply With Quote
Old 08-25-2009, 06:33 AM   #78
snoopyrc's Avatar
I dont think I can get much support for this car at the LHS here in North Georgia. I would like to try it but IDK.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 08-29-2009, 10:04 PM   #79
I just order some parts from hkshobby.com. He seems to have stock all the parts for the VM2. I also ran the ABC hobby mini series in Socal with the VM2 and it is pretty competitve with the HPI and the ABC genetic car.
afung1 is offline   Reply With Quote
Old 08-30-2009, 06:59 AM   #80
cyclone x's Avatar
Originally Posted by Nemo racing View Post
ATOMIC development has present a new evolution product for the serious race level. Is call Advance M-Chassis VMII.
Specification:
* Dual Belt Drive, 4WD drive train.
* 5 to 6-cells, machined 2.5mm thick FRP main chassis and upper deck.
* Ultra Light Weight Front Spool, Center Direct-drive and Rear Ball Differential.
* Adjustable Front / Rear Anti Roll-Bar (Need to buy separately)
* Adjustable Front / Rear Downstops.
* Adjustable Steering Ackerman (Five different position available)..
* Adjustable Front / Rear Lower Arm Position (+- 0.75mm)
* Adjustable Front / Rear Upper Camber Link position.
* Adjustable Front / Rear Camber.
* Default 4 degree Front caster (Optional 0, 2, 6).
* Adjustable Front / Rear Toe-in.
* Reinforced M-Class Wheel included (One Set).
* Durability Universal Swing Shaft (Front and Rear).
* Oiled Ball Bearing set included.
* Aluminum made oil shock cylinder.
how much is this car
Chase Chandler
Sponsors:HOTBODIES Express .The Track. Stevo Racing
Cars: VE8, F104 PRO, B4.1, HPI BLITZ, Losi SCTE
cyclone x is offline   Reply With Quote
Old 08-30-2009, 09:47 AM   #81
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
Approximately $240.
IIGQ4U is offline   Reply With Quote
Old 08-31-2009, 10:13 AM   #82
heretic's Avatar
does this car use regular TC wheels ? ( diameter the same ?)
If so, then I'm buying one ! I am not interested in realistic bodies and tire size , I just like the smaller race TC.
I already have the mini xray with stratus bodies but the CG of the car is a bit too high to my liking.
heretic is offline   Reply With Quote
Old 09-08-2009, 05:56 PM   #83
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
DCJ UJ for atomic
www.kkeprc.com
Give the best while u can !
kschu is offline   Reply With Quote
Old 09-11-2009, 12:53 PM   #84
over gear's Avatar
Trader Rating: 15 (100%+)
my VM2 is almost ready for action.
over gear is offline   Reply With Quote
Old 09-12-2009, 09:31 PM   #85
Nice.
Isaac is offline   Reply With Quote
Old 09-13-2009, 08:59 AM   #86
billjacobs's Avatar
Default impressions after building vm2
I purchased a vm2 last week and built it this past friday. Purchased from HKShobby in california and it arrived in 2 days via usps priority. Here are my impressions:
The chassis is indeed fiberglass layered with graphite. In stock build the chassis is very stiff, so I am not sure if 100% graphite is needed.
good:
1) excellent instructions and well packed and separated parts in box
2) good quality parts, although a little sanding is necessary (very little on the top and bottom of the front knuckles)
3) kit goes together easily and fairly quickly
4) basically a 1/12 scale cross between a tamiya 416 and xray t2 008
5) almost all the parts are already hopped up and it's very light
6) any lipo battery will fit because the battery sits next to the bulkheads, not under them.
7) spare parts are inexpensive ($4-$5 for a pair of arms, knuckles, or chubs, $5 for belts, etc.)
8) kit setup wheelbase fits the abc bodies perfectly
cons:
1) shocks are ok, I used spare tamiya trf shocks. you can't compare the smoothness between the 2, although in all fairness, I don't think any shocks are as good as tamiya trf
2) ball ends pop off too easily when adjusting links. They should have used captured ends on the c hubs and rear uprights (I might change to xray ends, we'll see)
3) plastic wheelbase shims should have been aluminum. I changed to aluminum shims and everything is tighter and smoother
4) for lipo, the battery stops don't work (except for 1 on the inside- you have to cut it though.) Batteries have to be taped in.
Overall, given the competition (abc genetic, hpi cup racer) this is a great kit, and at about $245 is a great value among the current mini chassis. I have yet to run it, but it's basically a 1/12 touring car scaled down, and since it has won almost all of the mini series races, you know it's good.
Build tips:
1) the kit setup has about 3.5' of rear toe. Each mm spacer is 1.5'. I replaced the 2mm spacer with 1mm and now the toe is 2'.
2) use an xray 3mm reamer on the inner holes in the arms, makes suspension travel much smoother.
billjacobs is offline   Reply With Quote
Old 09-14-2009, 04:56 AM   #87
strodedawg's Avatar
hello,
i am going to purchase one of these cars and have a few questions:
1- are there any mandatory upgrades for this car?
2- do they sell an actual touring car body (miss my mini corally)?
3- hks sells the car, where can i get a tourer body?
4- what power do people generally run in this car?
thanks in advance
Team Whiteknuckle-JM
TLR 5B-e 8s Hitec/JX/HW/Poseidon RC/SMC
Tekno EB48SL 4s Hitec/JX/HW/Tekin/SMC
Serpent s120 LTR Hitec/??/??/??/??
GRP/Dynamite/Grafil/Punched RC/RC monster/AKA/DE racing/LFR
strodedawg is offline   Reply With Quote
Old 09-14-2009, 06:20 AM   #88
abailey21's Avatar
Trader Rating: 36 (100%+)
I was lucky enough to see these cars at Vegas last week, I also saw the Top version as well.
These look really cool and its sad that Florida can't kick up and keep a mini class
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 09-14-2009, 11:18 AM   #89
over gear's Avatar
Originally Posted by strodedawg View Post
hello,
thanks in advance
1) i will replace the stock ball cups with tamiya's once the stock ones are worn out.
2&3) Spice makes a touring car body.
4) we run mabuchi motor here. people in Hong Kong runs 8.5t brushless
Old 09-15-2009, 10:37 PM   #90
The Top version? Top is making a mini TC?
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
M Chassis Conversion Kit For TT01-E & TT01 evanwest94 Electric On-Road 99 11-10-2013 01:18 AM
Electric on road dameetz Brunei R/C Racers 195 05-13-2011 07:42 PM
1/12 Touring Cars TommyBlazin Electric On-Road 20 05-07-2009 10:00 AM
