Old 06-28-2013, 06:53 PM   #556
Josh-n-ya's Avatar
Trader Rating: 73 (100%+)
Originally Posted by -jacob- View Post
Thank you Dan,
so im getting ready to pick up a VM2 Lipo from RC Mart
could anyone give me a list of spare parts?
and how many of each item to have.
not sure what breaks often.
i plan on racing this every other week.
I would really appreciate it.
Thank you for everyones time.
-jacob
Also throw away bearings that come with kit. Only good for a while. Look under xray at T3 section on EBAY and scroll down. They sell a set for $5.00 to 12.00 a set and there black. They are a hundred times better and dont get dirty as fast.
Josh-n-ya is offline   Reply With Quote
Old 06-28-2013, 08:39 PM   #557
-jacob-'s Avatar
Just bought VM2 lipo
Very excited
www.teameamotorsports.com
www.seattlercracers.com
-jacob- is offline   Reply With Quote
Old 06-28-2013, 10:04 PM   #558
-jacob-'s Avatar
Originally Posted by Dan View Post
Only thing I have broken is two rear arms, one of the plastic shock mounts, and bent a rear swaybar. I haven't broken anything else in a while though.
We have a few other guys running VM2's also. From what I've seen, in addition they have also broken front arms, spool cups, a universal, and not sure what else. Maybe some more people can chime in on what they broke.
Thanks man,
yeah to our fellow VM2 owners.... if you guys could give me some history.... so i can stock some spares.
Dan -do i use stock spur gear? and what size pinion...i will be running 21.5t since im a noob
Thanks buddy
Old 06-28-2013, 10:18 PM   #559
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
No, stock spur is 100T. I'm running a Kimbrough 76T spur, but find the smallest spur you can put on it. I think they made 64 pitch spurs down to 72T if I'm not mistaken. Pinion, using 55mm diameter tires, try 45-50T depending on size of your track. We race 21.5's blinky here at our track. Plenty fast for the size of these cars.
Dan is offline   Reply With Quote
Old 06-28-2013, 11:36 PM   #560
The Spec R diff for the Xray T2 should drop right in. Its 34T pulley and is under the parts page for the VM2.
As for the TRF417 spool, I'm not sure if it fits. You'll need the equivalent Xray T2 compatible unit... but you should see if EGR Mart will ship the Atomic one to your country. Its really inexpensive.
Thank you for the reply!!^^
my English is not good...
so that I can use SPEC-R DIFF FOR the XRAY T2 on my VM-II???
by the way..
I still have some question...the ATOMIC parts FRONT SPOOL is plastic...
it's very easy to broke...because I am using SPEED PASSION 5.5R with Turbo~
I saw the parts on ATOMIC RC's website~there's no aluminum front spool...
is there any optional parts that made with METAL or Aluminum???
did any SPEC-R or XRAY metal/aluminum front spool fits VM-II
Thanks!!!
VERT GSX is offline   Reply With Quote
Old 06-29-2013, 02:23 AM   #561
Keep in mind that the Xray T2 -006/007 & the T2 008/009 diffs are not the same. Im not sure which one will fit ,well they both will "fit" in the car but the pulley will be offset with the wrong one (so belt would be at an angle.
1101 is offline   Reply With Quote
Old 06-30-2013, 05:35 PM   #562
-jacob-'s Avatar
can anyone confirm this?
Old 06-30-2013, 08:24 PM   #563
Dan
Dan's Avatar
Yeah, I think it was 34T versus 38T for the later ones. 34T is the one you want for VM2.
Old 06-30-2013, 08:26 PM   #564
Dan
Dan's Avatar
by the way..
Thanks!!!
Spec R diff for T2 is same part number as the one for VM2. Not sure who makes a metal T2 spool.
5.5T in a mini? You are insane!
Old 06-30-2013, 10:54 PM   #565
-jacob-'s Avatar
Wow. Didn't catch that. Yes 5.5 is nutzzzz!
Old 07-01-2013, 06:55 AM   #566
Josh-n-ya's Avatar
5.5 is to slow! You really need a 4.5! Do it!!!!
Old 07-01-2013, 09:12 AM   #567
Old 07-01-2013, 10:43 AM   #568
Default hks hobby
has anyone brought any parts from them lately ? or is it best to order from egrracing ?
bigtee is offline   Reply With Quote
Old 07-01-2013, 04:56 PM   #569
Josh-n-ya's Avatar
HKS is fine also Atomic!
Old 07-01-2013, 04:58 PM   #570
Josh-n-ya's Avatar
I want to know how many pieces you end up with after test run?
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
M Chassis Conversion Kit For TT01-E & TT01 evanwest94 Electric On-Road 99 11-10-2013 01:18 AM
Electric on road dameetz Brunei R/C Racers 195 05-13-2011 07:42 PM
1/12 Touring Cars TommyBlazin Electric On-Road 20 05-07-2009 10:00 AM
