Atomic VM2 M-Class Chassis
#496
Seems like the QC just keeps getting worse.... My previous VM2's were better than this.....
Chassis is all straight....bolt on upper deck, chassis is now tweaked...FML
#502
I have updated mine to a BEZERK RC custom lipo schassis which uses the new style floating servo mount and has 3 mounting positions for shorty lipo packs.
Works well.
tony
#503
My chassis came pre-tweaked. The low friction front belt have slanted teeth. Got large TC wheels. Got 1 out of four wheelnuts. Should I go on?......
#504
Mine to. I have the original one and it's only 2 problems were the belt pulleys on the centre lay shaft slipping off the pins and rubbing on the bulkheads a couple of shims fixed that and the front king pin pivot balls not doing up tightly on the set screws.
Works well.
tony
Works well.
tony
#506
#508
Wow, I bought my VM2 a couple of months ago and have run it dozens of times now with the only issue being a screw backing out of one of the steering knuckles. The chassis was perfectly flat after building and it had the correct wheels. My only true complaint was the shock orings were very sticky. Two works ok and got better over time but two weren't able to be used at all. Swapped them out for something I had in my box and everything worked out fine. Using Sweep mini tires all around and a touring car body, my VM-2 is within a couple of tenths of the fastest 10th touring cars on a low bite carpet track. I keep asking but they won't let me race it with them yet so i'm stuck running my S411 in the races.
#509
@ I)arkness & defMondo
Thx for the links! I'll have to see if he ships overseas.
The best part of the build so far was putting the vmii away and finding Tony Gray's FB page from Berzerk RC. I haven't laughed so much in a long time. Thank you Mr. Gray for relieving me of my vmii frustrations for a day!
Last edited by Sydewynder; 05-14-2013 at 03:43 PM. Reason: Grammar: I iz bad at it.
