Old 05-08-2013, 08:05 AM   #481
Dan
Dan's Avatar
Trader Rating: 43 (100%+)
http://www.speedtechhobbies.com/inde...ilter_name=cso
Its a CSO Racing servo mount. Mostly any mount will work. You'll have to drill and countersink another hole on the chassis. I also cut off the little nub on the side of the chassis too.
Dan is offline   Reply With Quote
Old 05-08-2013, 07:15 PM   #482
Josh-n-ya's Avatar
Trader Rating: 72 (100%+)
Thats where that other cso mount went! Looks good Dan!
Josh-n-ya is offline   Reply With Quote
Old 05-08-2013, 07:31 PM   #483
Dan
Dan's Avatar
So I can expect to see an orange one on your car by the next race.
Old 05-08-2013, 10:07 PM   #484
The Orange one was suppose to go in my car.
Sydewynder is offline   Reply With Quote
Old 05-11-2013, 02:35 PM   #485
Dan
Dan's Avatar
Blah, removed 50% of the slop with new hub bearings and Tamiya 4.8mm ball connectors but still very sloppy, especially up front. The C-hub lower hinge pin hole is too big. Can change the caster a few degrees just by moving it around a little.
Wished someone made a high quality 4WD mini. Got to bug Cam at the next race and see if TOP mini suspension parts will work.
Old 05-11-2013, 03:05 PM   #486
Try Xray parts?
Old 05-12-2013, 09:32 PM   #487
I)arkness's Avatar
has anyone run the belt on the opposite side (diffs flipped over) like on the xray t4?
only reason i ask, was i had clearance issues with my servo hitting the larger belt
B.Portelli
Hyper RC - Metro Hobbies - RAB Hobbies - Wild Turbo Fans
Off road - Schumacher - R1Wurks Australia (Coupon Code - R1BP5%)
On road - Race Opt - Team Powers
I)arkness is offline   Reply With Quote
Old 05-12-2013, 09:42 PM   #488
Brad I haven't run it that way. It looks like it will will clear the battery. I guess it was set up like this because originally the car had a rear diff and something to do with the diff screw loosening (my assumption).
Is the front belt rubbing on the inner mounting tab on the servo?
Old 05-12-2013, 09:43 PM   #489
Dan
Dan's Avatar
I think most people are running the longer belt along the battery side. I do it for bit more room on electronics side to stuff my wiring neatly.
Old 05-12-2013, 10:02 PM   #490
I)arkness's Avatar
yeah there was no way the belt was going to fit, and i used a different servo mount which made it worse, as the kit plastic ones didnt even want to tighten up due to the two screws hitting each other.
i must agree not the best kit as in terms of build quality, i even got the wrong half of the gear diff, one side 38 the other 34, and a few screws missing. luckily i got it from a LHS so will get replaced.
B.Portelli
Old 05-12-2013, 10:13 PM   #491
Josh-n-ya's Avatar
Funny things about this kit and the things you have to do to get rolling! But once you do its pretty cool car. I moved the belt as like my xray to see what would happen for handling but pretty much the same results. I do know that the aluminum servo holders clear the belt for some reason though. I wish Xray made one of these cause the quality would be better than this!
Old 05-12-2013, 10:21 PM   #492
I)arkness's Avatar
yeah funny you mention that, as i was starting to pull bits off my old t2 008 as its a direct swap over on some parts
B.Portelli
Old 05-12-2013, 10:56 PM   #493
Josh Xray made a mini years ago, T1M. I died along with the Corally mini Assassin and the Yokomo MR4 TC mini.
Old 05-12-2013, 10:59 PM   #494
The original kit didn't have screws hitting problem. Atomic forgot about the thinner chassis in the Lipo version....
Old 05-12-2013, 11:01 PM   #495
You guys realize by flipping the front belt, the hole pattern in the spool are now spinning the wrong way.
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9055 02-23-2017 03:26 PM
M Chassis Conversion Kit For TT01-E & TT01 evanwest94 Electric On-Road 99 11-10-2013 01:18 AM
Electric on road dameetz Brunei R/C Racers 195 05-13-2011 07:42 PM
1/12 Touring Cars TommyBlazin Electric On-Road 20 05-07-2009 10:00 AM
