Old 09-24-2012, 11:34 PM   #421
Trader Rating: 56 (100%+)
I might try a 40wt in the rear. A good thing too is have the VM2 go thru a setup station. Get all the kinks out.
sipaboy is offline   Reply With Quote
Old 09-25-2012, 12:10 AM   #422
Dan
Dan's Avatar
Trader Rating: 40 (100%+)
Almost done.... just need to get a new ESC and paint a body. Trying our TRF mini shocks this time, little bit smoother than the stockers.
Dan is offline   Reply With Quote
Old 09-25-2012, 08:09 AM   #423
Trader Rating: 22 (100%+)
Originally Posted by sipaboy View Post
For those who built their lipo version. Which shock piston did you end up usng? And what weight oil? Instruction didn't have any indication on what to use.
I am using 50wt. all around and the 2 hole pistons.
Using Muchmore Racing 45WT with TAMIYA TRF 3-hole internals.
JoeyE is offline   Reply With Quote
Old 09-27-2012, 10:04 PM   #424
Almost done building my VM2. I replaced all the ball cups/ball ends with TAMIYA. Aluminum blue screws on top and stock on the bottom. The shock internals are all TAMIYA.
Old 09-30-2012, 10:59 PM   #425
Josh-n-ya's Avatar
Trader Rating: 71 (100%+)
Seems to be the car to look out for in the Season End Series!
Josh-n-ya is offline   Reply With Quote
Old 10-08-2012, 11:39 PM   #426
Josh-n-ya's Avatar
Oh, that would be my car to look out for!
Old 10-09-2012, 12:10 AM   #427
Nice~!
Old 10-12-2012, 09:03 AM   #428
Trader Rating: 15 (100%+)
Default VM II
I really love my VM2 but there is no class for it at my local track....so here it goes on the bay http://www.ebay.com/itm/Atomic-VM-II...item3a7a96140d
slowhand55 is offline   Reply With Quote
Old 12-16-2012, 12:47 AM   #429
Josh-n-ya's Avatar
So best set up advise I could give would be use the manual. It says 5mm droop in front 4mm in rear. Thats what I am doing with 5mm ride height all the way around! Works like a charm. 45wt shock oil front and 40wt rear. 2mm camber front and rear. 0 toe in front and 3mm rear. have tried several bodys and all have worked well.
Old 01-24-2013, 07:34 PM   #430
san.'s Avatar
Trader Rating: 59 (100%+)
To all near the NJ/NY/CT/PA area, Critters Raceway in Fairfield, NJ will be running this class every Fridays starting Feb 1st, 2013.
Our official thread: http://www.rctech.net/forum/racing-f...ing-forum.html
Sai (Atomic-USA), please contact us. We would like to stock your product.
Awesomatix USA||Roche RC USA||Sanwa
san. is offline   Reply With Quote
Old 01-30-2013, 11:47 PM   #431
Back in stock again at egrracing.com . Looks like plenty of parts available as well.
Just bought one, been lusting over this & the Fujin for years now.
Great thing is my spare xray diffs should fit.
What body should I get. What fits ??
Most of the Spec-R race bodies are out of stock everywhere, and the SPEC-R give the wheelbase on those bodies, not very helpfull.
I had to just get a Blitz Mini RS4 WB 210mm body, Im hoping it actually fits.
http://www.rc-mushroom.com/product_i...m-body-p-17715
Any spares I'll need? I bought diff gears & suspension arms.
1101 is offline   Reply With Quote
Old 02-07-2013, 11:06 PM   #432
Josh-n-ya's Avatar
ABC bodys fit perfectly! I bought a sedan boby that worked great from Spec R. Problem was they wouldnt let me run it at my local track!
Old 02-09-2013, 07:40 PM   #433
ghiro's Avatar
Send a message via Skype™ to ghiro
Time to rebuild my VM2.
I would really like to upgrade it with the new Lipo version chassis instead of the old one. Anyone knows if the newer chassis is compatible with the previous model parts?
Capricorn TE01-Associated RC10R5.1-Atomic VM2-Serpent Cobra811 BE-Honcho-Losi MRC/RcBros-SandScorcher-MERV
DJI' F550-HubsanX4-Toy'sPort Zorro
ghiro is offline   Reply With Quote
Old 02-09-2013, 07:58 PM   #434
Dan
Dan's Avatar
Yes, see my post on 9/20. It will all bolt up. Only minor issue is the servo is moved in and back more ever so slightly. So you'll need to adjust the steering turnbuckle from servo to steering post.
Old 02-09-2013, 08:02 PM   #435
ghiro's Avatar
Thanks Dan, i'll buy the chassis right away and start the rebuild.
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
M Chassis Conversion Kit For TT01-E & TT01 evanwest94 Electric On-Road 99 11-10-2013 02:18 AM
Electric on road dameetz Brunei R/C Racers 195 05-13-2011 08:42 PM
1/12 Touring Cars TommyBlazin Electric On-Road 20 05-07-2009 11:00 AM
SEO by vBSEO 3.5.0
