Like Tree1Likes
Old 09-22-2012, 10:33 PM   #406
Josh-n-ya's Avatar
Trader Rating: 75 (100%+)
Originally Posted by Dan View Post
Got my VM2 Lipo in. For those that are interested in upgrading to the thinner and slimmer chassis rather than buying a new car, I have good news. The bulkhead and motor mount holes all line up with the original VM2. The only main difference is the servo mount holes have moved more inwards. See attached picture of new chassis placed on top of old. The thinner upper deck also is a bolt on affair with the original VM2.
Oh yeah....the lipo version comes with green dish wheels.....interesting..
So Dan, everything from the old kit is the same to the lipo version other than chassis?
bigtee, they make a sway bar kit for the VMII. May cost some money but no mods are needed. Pic and choose your battles is what my wife always says! ah ha
Josh-n-ya is offline   Reply With Quote
Old 09-22-2012, 11:50 PM   #407
Dan
Dan's Avatar
Trader Rating: 46 (100%+)
No, there is more than just the chassis. The upper deck, front shocktower, and bulkheads/motor mount are different. Oh yeah, comes with rear gear diff instead of ball diff. But the changes are all really minor aside from chassis. The upper deck and the lower deck are interchangeable between the old and new. I hope the thinner lipo chassis will help generate more grip on an asphalt track. The original had a thick and very stiff chassis that made the VM2 harder to tame.
The dealbreaker is that it comes with green dish wheels instead of white.
Dan is offline   Reply With Quote
Old 09-24-2012, 06:47 AM   #408
Josh-n-ya's Avatar
I was reading about the VMII after I posted that and saw that there were a few other parts that changed! Pretty odd that it came with green wheels. They must be trying to get rid of some old stock! Are you going to be racing the year end series at Norcal?
Old 09-24-2012, 07:55 AM   #409
Trader Rating: 27 (100%+)
Putting together my VM2-Lipo version and noticed that the screws are weak/soft, missing E-clips, plastic shock parts are not molded right, etc...
Overall the kit is pretty good. Can't wait to try it out.
I'll post pictures later this week when I finish.
JoeyE is offline   Reply With Quote
Old 09-24-2012, 08:04 AM   #410
team green's Avatar
You might want to use different balls and ballcups also.....
I will never go back to brushed motors or NIMH's!!!!
Awesomatix EVO2
Mugen MTC1
Associated B6
TLR 22-4 2.0
team green is offline   Reply With Quote
Old 09-24-2012, 08:08 AM   #411
Trader Rating: 62 (100%+)
Did some testing yesterday between the offroad heats. Playing with shock position , droop and I am near the ideal setup for my style of driving. Only thing I was using a TC body. I will try to run it with an ABC body today or tomorrow. Im debating if I should get some sways. The travel is so minimal that maybe it would or would not make a difference. I was running the Citrix 17.5 and was fast enough with a 44 pinion 85 spur combo. Temp was around 120 degrees . I can still gear higher. Way smoother than the other mini I have owned and lately I have owned a few.
I wish we had some posted setups by other Atomic owners. The setup on the manual is a good start with the proper tires.
sipaboy is offline   Reply With Quote
Old 09-24-2012, 08:18 AM   #412
team green's Avatar
Henry it's Jason.... Was the on road track prepped yesterday? I'll be there Wednesday to practice.
Awesomatix EVO2
Mugen MTC1
Associated B6
TLR 22-4 2.0
Old 09-24-2012, 08:41 AM   #413
Nope it wasn't. It was dusty especially outside the lines. If you're going wednesday, you might want to ask the Norcal crew if they blew the track. If they didn't they might do it if you ask. No onroad race this weekend either. I am going sunday to practice both on/off road
Old 09-24-2012, 08:44 AM   #414
The turnbuckles attached to the C hubs and rear carriers have a hole on top. I placed in a short screw on it so it doesn't pop out.
Old 09-24-2012, 10:02 AM   #415
Ball cups and ball ends huh? I did noticed that they didn't have a nice tight fit. It popped on really easy. I'll change them out to something else. Thanks for the info.
Henry, stay off the walls~!
Old 09-24-2012, 10:14 AM   #416
Trying my best. Wheel finger ain't 100% anymore from my job. Trigger finger too. My body is taking it's toll from my profession. Yesterdays run was more wall free. A TC6 foam bumper fits but needs some trimming in the back when the wheel turns either way. The tires hit the bumper on the turn. Maybe 1/4 inch trim on each side. Then you trim the front depending on your body. I think kyosho got those really slim foam bumper. The Xray has the best.
Old 09-24-2012, 10:29 AM   #417
Henry...I think you need to just lay back and be like Mr. Mayigi now. I think you have beaten all the Cobra Kai's by now.
What body to good for this chassis? Tall K-car or something lower? Old school mini cooper looks fun though.
Old 09-24-2012, 10:40 AM   #418
Joey, I know I am but can't reverse the damage. My son opened up his own inside a mall in Landess ave.and the youngest[13] is 5'8" now. They're taking over kinda. Body will be any coupe. The Sunny is the best I think.. Seems to be a lot of the racers know that too and you'll see a lot of them using it. I like the TE27 and the Proline rally 210mm. Datsun 240z?
Old 09-24-2012, 04:57 PM   #419
For those who built their lipo version. Which shock piston did you end up usng? And what weight oil? Instruction didn't have any indication on what to use.
I am using 50wt. all around and the 2 hole pistons.
Old 09-24-2012, 10:13 PM   #420
Josh-n-ya's Avatar
I use 50 front and 40 rear but thats in my Genetic! I know sipaboy did a marathon build right before Top Gun. Now its time to really go through it and take care of the small imperfections!
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
M Chassis Conversion Kit For TT01-E & TT01 evanwest94 Electric On-Road 99 11-10-2013 01:18 AM
Electric on road dameetz Brunei R/C Racers 195 05-13-2011 07:42 PM
1/12 Touring Cars TommyBlazin Electric On-Road 20 05-07-2009 10:00 AM
