Old 08-15-2012, 02:26 AM   #376
tony gray's Avatar
In the States? HKS HOBBY have them in stock now.
tony gray is offline   Reply With Quote
Old 08-15-2012, 11:42 AM   #377
John.C's Avatar
Trader Rating: 36 (100%+)
Originally Posted by IIICJACKIII View Post
Where is the best place to get one of these cars? Also is there any parts and/or upgrades that should be done right away to be competive? Ill be running at MRH this winter.
Info can be found here.
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 08-15-2012, 07:48 PM   #378
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
Anyone with the lipo version confirm it all the screw holes line up with the previous chassis?
Dan is offline   Reply With Quote
Old 08-16-2012, 12:36 AM   #379
IIICJACKIII's Avatar
Thanks, I'll check that out.
Team Psycho Cells
IIICJACKIII is offline   Reply With Quote
Old 08-16-2012, 06:19 AM   #380
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Game over your hooked!!!!!!!!!!! Greg Mann is getting a touring car as well. He has the bug.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 08-16-2012, 06:58 PM   #381
Yeah, I guess you could say that. Lol
I'm really liking onroad. You racing this sat.?
So when is he getting it? Whats he getting?
Team Psycho Cells
Old 08-16-2012, 09:06 PM   #382
Default paging manny
What xray parts did you use on the atomic vm2?
bigtee is offline   Reply With Quote
Old 08-16-2012, 09:43 PM   #383
Dan
Dan's Avatar
Body posts, diffs?? lol, not sure what else...
Old 08-17-2012, 10:45 AM   #384
wyd
Tech Legend
wyd's Avatar
I will be at MRH on Sat. Greg is looking at a Sakura Xi but might buy a new TC6.1. He is looking to have everything to race by end of September.
Old 08-17-2012, 11:17 AM   #385
Default question on atomic vm2 lipo
what are most people running in the car solid front axle or are the putting a ball diff and the rear are they using the stock gear diff or putting in a ball diff as well
Old 08-26-2012, 10:27 PM   #386
Trader Rating: 62 (100%+)
For those lucky ones who have a VM2 lipo. How is the new car? Any setups you can post that works well for outdoor prepared tracks? One more favor for those with the older VM2. Can you post any setups for outdoor track. Thanks looking forward for any pictures of their VM2.
sipaboy is offline   Reply With Quote
Old 08-27-2012, 09:16 PM   #387
Dan
Dan's Avatar
Norcal Hobbies right?
Running older VM2. Car out of the box has way too much oversteer. However, got it to the point where it handles great in the morning and late afternoon. It seems to become difficult to drive in middle of the day when the track temp is highest. (Even when trying out Team Powers mini tires)
Solaris Hard Premount Mini tires all around. Stock shocks/springs. Front stock springs are really stiff. Even with 40WT front/35WT rear. More of an issue at FPR, as the front will bounce thru the turns on bumpy tracks.
Hardest swaybar front, softest swaybar rear. F/R ride height at 5mm.
-1 Camber all around. 0 toe front. -2.5 rear toe.
Spool front. Rear Spec-R gear diff with 1000WT oil.
Cirtix motor 76T 64P spur. 40T pinion. May drop down two teeth on pinion since the new track setup no longer has the long sweeper at the end of the straight.
I'm not a great driver but when the track temps cool down, it really comes alive and I bet it would have no problem keeping up with the fastest Genetic. Perhaps in the fall, I'll have better luck with the car.
Old 08-28-2012, 09:56 AM   #388
I bought a used VM2. I'm waiting for the mailman to deliver it. Its suppose to have front and rear gear diff. Can I pack the front diff with 200k and would it somewhat act like a spool? Dan, thanks for the setup tips.
Any input on the Lipo chassis version?
Old 08-30-2012, 01:44 AM   #389
What body were you running? Also you notice a big difference with ot without sway bars? Thanks
Old 08-30-2012, 09:49 PM   #390
Dan
Dan's Avatar
Packing the front diff is another option. Might even work better, but I have not ordered a new gear diff to try that out. I want to get the lipo version but not in a rush. Thinner main chassis should help grip a bit more and reduce scrub in high speed corners.
Running a Tamiya Honda S800 body. Not the best body for racing but just staying realistic for the class. Its beatup now. I have a spare Swift body and ABC 240Z that needs painting. I'm most likely racing at Norcal this Sunday. Look for the silver S800 body with the red stripes.
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
M Chassis Conversion Kit For TT01-E & TT01 evanwest94 Electric On-Road 99 11-10-2013 01:18 AM
Electric on road dameetz Brunei R/C Racers 195 05-13-2011 07:42 PM
1/12 Touring Cars TommyBlazin Electric On-Road 20 05-07-2009 10:00 AM
