Old 05-03-2012, 07:20 PM   #346
Dan
Dan's Avatar
Trader Rating: 46 (100%+)
That sucks to hear. I was very close to ordering another one (as backup for parts)
Dan is offline   Reply With Quote
Old 05-03-2012, 08:20 PM   #347
durtbag's Avatar
Good news actually, I used the contact function on EGR's web page and got a response same day. The missing gear diff and blingie rear hubs will be sent to me. They are insistent that the chassis is the carbon version, it certaintly looks like carbon, and measures 2.59mm thick.
I'm happy with the quick response from EGR, and will get on with the build.
Pissed to impressed all in one day.......
AW HELL RICKEY, I WAS HIGH WHEN I SAID THAT!
durtbag is offline   Reply With Quote
Old 05-03-2012, 10:17 PM   #348
Full carbon chassis or FRP center carbon outer?
Get the edge of the chassis wet with a little water. You can tell easier if yours is full carbon or fiberglass laminated with 2 outer carbon layers. The full carbon has multiple lines (layers) when you look at the edge. Also when wet the color and transparency or lack of it is even through out the edge. On the FRP sandwiched one you should see 2 lines each representing the 2 layers of carbon on the outside. Plus the center fiberglass core is more translucent.
The above can be apparent if you CA the edge of your chassis.
Atomic never changed the box even on the interim Carbon chassis only, no gear diff and Al rear upright version.
@durtbag. Be glad now you have an extra ball diff. I'm sure if it was packed right to begin with you wouldn't be getting it.
Sydewynder is offline   Reply With Quote
Old 05-04-2012, 02:33 AM   #349
ghiro's Avatar
Send a message via Skype™ to ghiro
Received my Limited Ed.n an hour ago.
The box is exactly the same as the "stock version" but theres a sticker in wich is described as Limited Edition. Lefft the car in the package and back to work i've found an E-Mail from EGRmart:
"Hi, thank you for using our products.
We are deeply sorry that the VM-II 1/10 M Series Touring Car - Limited Edition has some packing problem.
The following parts are missing,
VM-067 - Gear Differential set (For VM-II)
VM-020-AL - VM-II Alu. Rear Upright
For apologize, the missing parts are sent via Registered Air Parcel at 4-May-2012, the Tracking No is:xxxx xxxx xxxx x "
Well no big deal, they are serious and just in time to avoid me a bad surprise.
Apreciate EGRmart's timing and service .
Capricorn TE01-Associated RC10R5.1-Atomic VM2-Serpent Cobra811 BE-Honcho-Losi MRC/RcBros-SandScorcher-MERV
DJI' F550-HubsanX4-Toy'sPort Zorro
ghiro is offline   Reply With Quote
Old 05-04-2012, 09:30 AM   #350
durtbag's Avatar
Yeah, I got the same e-mail this morning. They must have packaged a few wrong and are now correcting the shortages, good service. And we get a ball diff as well.
Old 05-05-2012, 03:46 AM   #351
Pinion King's Avatar
Send a message via MSN to Pinion King
I got the same email as well. Got 2 on the way.
Any tip and tricks for building the car?
Pinion King is offline   Reply With Quote
Old 05-07-2012, 08:20 AM   #352
durtbag's Avatar
Just a regular build, I used the 3mm X 8mm button heads for the bulkhead caps b/c the 6mm are too short and don't go deep enough into the bulkheads for a positive lock. Ball cups are really not tight enough on the ball studs, I will replace these later.
Here is my fresh build.
Old 05-07-2012, 01:25 PM   #353
Dan
Dan's Avatar
Is it just me or does it look like EGR Mart is no longer supporting the VM2?
Old 05-07-2012, 02:20 PM   #354
durtbag's Avatar
I'm kinda feeling the same way. I think the class really never took off and sales of kits are low, so eventually the VM-II will no longer be made. To bad, I think the kit is pretty good, for the last price paid. It was more of a novelty buy for me, hey, a TC mini for much less than I have in my M05. I will have to make a large parts order and hope for the best.
Old 05-07-2012, 07:20 PM   #355
Dan
Dan's Avatar
Doh, I really should have placed an order for another kit as backup parts.
Old 05-08-2012, 12:59 AM   #356
Are you sure about that?
Old 05-08-2012, 07:30 AM   #357
Dan
Dan's Avatar
Looks like parts have been pulled from their site.
Old 05-08-2012, 09:14 AM   #358
durtbag's Avatar
?? I still see parts listed.
http://www.egrracing.com/shop/index....th=154_157_317
Old 05-08-2012, 10:04 PM   #359
Dan
Dan's Avatar
Whoops, nevermind! The VM2 tab on their front page was not linking right. Phew, glad to see parts are still available. I'll order a kit for backup parts hopefully once they are back in stock again.
Old 05-14-2012, 11:45 AM   #360
Dan
Dan's Avatar
http://www.egrracing.com/shop/index....5543698cf84ab6
Ok, I take it back, I'm glad I didn't order a VM2 last time.
Looks like the first real big update for the VM2 is here, lipo version! Thinner chassis with no cutouts and a host of minor updates. Rear gear diff standard. Says it will be ready to ship in June. Going to order one!
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
M Chassis Conversion Kit For TT01-E & TT01 evanwest94 Electric On-Road 99 11-10-2013 01:18 AM
Electric on road dameetz Brunei R/C Racers 195 05-13-2011 07:42 PM
1/12 Touring Cars TommyBlazin Electric On-Road 20 05-07-2009 10:00 AM
