Old 11-23-2011, 08:48 AM   #256
Originally Posted by ghiro View Post
In my case i use the ball diff on the front so i want it tighter than how it's required in the rear end. I've ordered some ceramic balls and sanded the diff plates: i keep testing but i start to believe i'm better go back to spool, looking for something stronger than the stock one. Any advice?
I'm use a gear diff in the front and rear. The front has 100k wt. oil so it very tight but still has some diff action for good initial turn in. The rear has 1k oil.
You say you need something stronger than the spool? What's breaking? It's a fairly simple piece.
Sydewynder is offline   Reply With Quote
Old 11-23-2011, 09:14 AM   #257
ghiro's Avatar
Send a message via Skype™ to ghiro
Originally Posted by xenite400bhp View Post
ghiro..hows your gear diff? do you have any pic to share?
Here the gear diff.
I meant i would like to find a spool not made in plastic
Capricorn TE01-Associated RC10R5.1-Atomic VM2-Serpent Cobra811 BE-Honcho-Losi MRC/RcBros-SandScorcher-MERV
DJI' F550-HubsanX4-Toy'sPort Zorro
ghiro is offline   Reply With Quote
Old 11-24-2011, 09:32 AM   #258
xenite400bhp's Avatar
Here the gear diff.
Thanks for the gear-diff photo ghiro..it does look solid and nice..btw, i did a test run this morning at my local track..it seems that the ball diff run perfectly. the only problem that occur this morning was the ball join at the rear keep popping out even if i hit a curb.minor accident. Lucky i have a lot of ball join set from my previous car which are more tight and solid. i suggest you do the same thing to avoid disappointment.
***MONSTER ENERGY***
xenite400bhp is offline   Reply With Quote
Old 11-26-2011, 11:51 AM   #259
ghiro's Avatar
First serious test run: W O W! What a Car!!!! I've replaced the front spool with the fixed ball diff. and find it a whole lot better, steering is more agressive and i can set faster lap times. The track is outdoor asphalt with a medium/high grip surface,small and technical design, something like 800sqM, usually with a 10.5T 1/10 Touring car lap times are around 14.5 sec's, today i was able to set a 14.2sec's Lap!!! The motor is a 10.5t SpeedPassion V3 one cell version, Hobbywing Xtreme stock Esc Boosted+Turbo, Savox low profile servo ( same i use with the WRC formula car) Venom 60C /Orion 45C 2S Lipo's. I gave a very hard times to the many 1/10 sedans on the track, it was the "cutie" of the track, once at the Pit it was the queen of the day, everybody was amazed and actracted . I'm very happy about this little bastard. I think it'll be it's name, gotta make some stickers .
Old 12-06-2011, 07:22 PM   #260
Default Testing the new batteries.
+ YouTube Video
Old 12-06-2011, 08:25 PM   #261
hanzo3's Avatar
Trader Rating: 55 (100%+)
What bodies fit with this? Anywhere besides HKS can I get parts?
Chris TRF419 TA05V2
TQ RC Racing Powered by teeth
hanzo3 is offline   Reply With Quote
Old 12-06-2011, 10:00 PM   #262
Any 210mm bodies i guess.. but if u want to try 225mm wb bodyshell..you need some messy modification.. but nothing is impossible.
Old 12-07-2011, 01:09 AM   #263
ghiro's Avatar
I'm trying to fit this 225mm chassis to the Atomic VM2:
http://racepf.com/mini-micro/socal-p...on-clear-body/
Old 12-07-2011, 02:21 AM   #264
have you bought that body? i guess u have to maintain the rear wheel position n bring the front wheel backward.. to fit the chassis.
Old 12-07-2011, 02:35 AM   #265
ghiro's Avatar
I bought two actually, my reference for the cut of the wheels is the front end. At the rear there's more room to allow the wheel to fit than at the front. Weird thing about this chassis is the cut sign around the wheels is more suitable to fit full 1/10 scale wheels
Old 12-07-2011, 08:11 AM   #266
Default 225mm wb bodyshell..
yes, you are right.. maybe the position that i told you earlier doesn't really look nice..it would be something like this.
Old 12-07-2011, 08:36 AM   #267
Trader Rating: 16 (100%+)
That body is designed to use 10th scale wheels
brettweir78 is offline   Reply With Quote
Old 12-09-2011, 01:42 PM   #268
Hi Guys. Is the VM2 still being made/sold.
Trying to find somewhere with it in stoock.
Cheers
1101 is offline   Reply With Quote
Old 12-09-2011, 08:53 PM   #269
Redko's Avatar
Cheers
Hi 1101,
this hobbyshop still have the VM2 in stock with quite a number of hop-ups available as well.
http://quantumracing-rc.com/index.ph...od&productId=2
--TAMIYA--TRF 419X, TRF 419, TRF 418, TRF 417V5, TRF 201, M-05Ver.2, FF-03R, TRF 101, F104WGP, F103RM, RM01
-- Infinity -- MUGEN -- SANWA -- HOBBYWING -- ProSpec -- ORION -- OS -- Muchmore -- Wild Turbo Fan -- Axon -- MTB
Redko is offline   Reply With Quote
Old 12-10-2011, 12:49 AM   #270
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
Still about $195USD and who knows how much shipping is...
Still waiting on EGR Mart to get some in stock. I'd order from HKS Hobby if they didn't have such a bad rep....
Dan is offline   Reply With Quote
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9055 02-23-2017 03:26 PM
M Chassis Conversion Kit For TT01-E & TT01 evanwest94 Electric On-Road 99 11-10-2013 01:18 AM
Electric on road dameetz Brunei R/C Racers 195 05-13-2011 07:42 PM
1/12 Touring Cars TommyBlazin Electric On-Road 20 05-07-2009 10:00 AM
