Old 06-02-2011, 01:41 PM   #181
The word is "lose" not "loose" Mr. H.
Sydewynder is offline   Reply With Quote
Old 06-02-2011, 02:37 PM   #182
Trader Rating: 28 (100%+)
The new owner is washed up.Don't let Johnny scare you. Mini should be a great class.
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 06-05-2011, 12:19 AM   #183
so hicks, u ready to sell me ur t3 11 yet
one2three_us is offline   Reply With Quote
Old 06-05-2011, 12:49 AM   #184
lol.....Not yet. Just bought the new Exotec t3 2011 chassis for it.
I have my gear diff on order.My V2 should be ready to go along with my TOP Sabre and T3 for Pete's 1st race.
Team I'm Over It
Old 06-05-2011, 12:58 AM   #185
ahh! i guess i have to keep waiting and dreaming. btw, I shall have those special lipo for u soon. waiting for next shipment. u want then in deans or bullets?
Old 06-05-2011, 01:06 AM   #186
Bullets please!
Team I'm Over It
Old 07-12-2011, 09:39 PM   #187
xenite400bhp's Avatar
Default Atomic VM2
Hye Guys,
Just want to let you guys know that I've just received my VM2 kit this morning. Kind of excited and cant wait to build it tonight. I also bought the Alu. center pulley and the sway bar set. =)
http://imageshack.us/photo/my-images...mage013ve.jpg/
http://imageshack.us/photo/my-images...mage012cn.jpg/
Btw, thanks for the Advice and Tips. Hope we can share more setup setting and others. =D
xenite400bhp is offline   Reply With Quote
Old 07-15-2011, 12:39 PM   #188
Default Rim
Hey guys, need some info. can this kit use the normal 1/10 touring rim? has any one tried it? photos would be great.
Thanks in advance.
Old 07-15-2011, 12:44 PM   #189
over gear's Avatar
Trader Rating: 15 (100%+)
Thanks in advance.
yes, but it'll look like a monter truck.
over gear is offline   Reply With Quote
Old 08-31-2011, 01:13 PM   #190
Default Help:Need some opinion and suggestion.
Originally Posted by hanulec View Post
after looking over my VM2 one more time I see the following modifications:
A. Upper suspension links (each)
1- XRay 302664 - T2 Ball Joint 5mm Unidirectional ; these are the parts with the 'dot' on them. i've used them on the inside upper camber links.
1- Team Associated TC5 Short (height) ball studs - 8mm or 10mm length (cannot remember) for use at the c-hub or rear hub
1- 3mm set screw - unknown length - to replace the turnbuckle
1- Team Associated ASC7230 T4/B3/T3 BALL END CUPS (12) - i cut these ball ends in order to make the link short enough to put 1-2 degrees of negative camber into the suspension. i rather cut these ends as they are cheap compared to the xray ones.
B. Steering Links (each)
1- Team Associated TC5 Short (height) ball studs - 5mm for use at the the steering knuckle
1- Team Associated ASC7230 T4/B3/T3 BALL END CUPS (12) - at the steering knuckle
1- kit turnbuckle
1- kit rod end
C. Shocks
1- 3mm x 10mm (i think) cap head screw to replace the grub screws holding the bottom on the shock ends to the lower suspension car
D. Front Spool
2 - XRay 305135 - T2'008 Composite Solid Axle Driveshaft Adapters (2) - to replace the Atomic Stock Units
E. Rear Diff
1 - XRay 34tooth diff from my old T2'008 - only swapped this unit in after the kit original diff screw broke
Hye guys,
I have a plan to upgrade my VM2 using the 3racing parts. especially the weak parts of vm2 kit that had been claim by several people. so here are the list of what I'm going to purchase. but before that I really need some feedback about the part whether its fit or not.
-http://www.myrcstation.com/webshaper...oductItem=3178
-http://www.myrcstation.com/webshaper...oductItem=2463
- no problem
-http://www.myrcstation.com/webshaper...oductItem=2900
-http://www.myrcstation.com/webshaper...oductItem=2471
-http://www.myrcstation.com/webshaper...oductItem=2901
1- kit turnbuckle
-http://www.myrcstation.com/webshaper...oductItem=2953
1- kit rod end
-http://www.myrcstation.com/webshaper...oductItem=4176
C. Shocks
-no idea
D. Front Spool
-Next upgrade
E. Rear Diff
-Next upgrade
Btw, this is my car.
Thanks in Advance
taff
Old 09-19-2011, 09:43 PM   #191
Trader Rating: 16 (100%+)
So my kit is on its way. Also a pile of spare parts. does any one have a good setup for indoor carpet. the car will be running the ABC motor and sweep tires. Thanks
brettweir78 is offline   Reply With Quote
Old 09-20-2011, 02:43 PM   #192
With this kit you can use 5.5t and tailgating the gas car. seriously.
Old 09-20-2011, 02:51 PM   #193
Thanks for the input, but for the class we run I am limited to the ABC black can motor. I just need to make sure that the car handles better than everything else on the track. If anyone has a setup that they use on carpet please post it up.
Old 09-22-2011, 03:04 PM   #194
Built the car last nite. It went together pretty well, but did have a small problem. One of the upper link turnbuckles has no threads on it. Now i need to find something else that will work. Other than that the car looks good.
Old 09-27-2011, 01:14 PM   #195
photos would be nice.
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
M Chassis Conversion Kit For TT01-E & TT01 evanwest94 Electric On-Road 99 11-10-2013 02:18 AM
Electric on road dameetz Brunei R/C Racers 195 05-13-2011 08:42 PM
1/12 Touring Cars TommyBlazin Electric On-Road 20 05-07-2009 11:00 AM
SEO by vBSEO 3.5.0
