Old 03-30-2010, 09:50 PM   #151
Check PM
Atomic-USA is offline   Reply With Quote
Old 03-31-2010, 12:15 PM   #152
rai913's Avatar
Default bodies
You mind pm'ing me too. I could use an extra body.
TIA
Rai
rai913 is offline   Reply With Quote
Old 04-28-2010, 04:03 PM   #153
Company Representative
SweepRacingUSA's Avatar
The Official entree form is up at RCsignup.com
HURRY!
Note: this event is a open tire competiotion, however racers will have chance to purchase Sweep tires at rock bottom price for the day! (Qty is limited for each driver)
SweepRacingUSA.com 2014 &2015 US. NATIONAL CHAMPION!
10th Buggy F1 TC 8th Buggy 8th Truggy GT8 M-Chassis Monster Truck(SRC) Bodies&Wings
SweepRacingUSA is offline   Reply With Quote
Old 06-21-2010, 07:29 AM   #154
Trader Rating: 69 (100%+)
All the atomics were fast and by the end of the day, they were pretty dialed. the problems that I had all day were the the links popping off after barely touching or lightly tapping. I saw other atomic racers break spool cups, shred cvd's.
Do you remember what parts you used to replace the ball links? I would rate the cars speed/handling very good but the reliability/durability poor.
If I can get the right end links, I think the car can be a force to reccon with
Markus is offline   Reply With Quote
Old 06-21-2010, 07:29 AM   #155
Location: 2.5 Miles South of Pentagon, Light years from reality
Default Atomic parts
OK folks,
Where in North America can I or my (LHS) get parts for this critter?
Rod
If you think gettin' older is bad; consider the alternative.
Buffalo 16 is offline   Reply With Quote
Old 06-21-2010, 07:36 AM   #156
Rod,
Right now it seems that only HKShobbies has parts in the US. I takes a while to get parts.
If you need parts immediately, check with Ray K. He seemed to be fed up with the Atomic and even told me he may saw the chassis in half and throw it away
I'm hoping he was just frustrated and decides to keep the car.
Old 06-21-2010, 07:59 AM   #157
A couple of shops in US had just obtained accounts with Atomic besides HKS. PM me with your location and I'll tell you where to get parts. Parts are not hard to get; just tell your LHS to stock them. Post here or PM me for technical support or warranty issues.
Old 06-21-2010, 08:10 AM   #158
Ray k's Avatar
Trader Rating: 46 (98%+)
Originally Posted by Markus View Post
Rod,
My order has been placed , I put the saw away, I will give this car one more chance!!!!!!
Rod if you need something let me know ,I probably have it . Plus I just placed yet another $120 order of parts and hop-ups (*^!!%!^(*!&*(&*()
Ray k is offline   Reply With Quote
Old 06-21-2010, 08:40 AM   #159
hanulec's Avatar
Trader Rating: 23 (100%+)
Guys - I got my vm2 pretty bullet proof. I will post the different parts I used in the next day or two along with some pics. 3-dee already sent me a pm about the observed issues. Sai Tam (Aka Atomic USA) and I will make sure to communicate them back to Atomic head quarters. The car is pretty fun. .. just a little fragile out of the box.
I'd love to see a picture of a broken cvd.
What bodies have you been running??
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 06-21-2010, 08:49 AM   #160
Thanks Hanulec!
post pics of your car too! We'll probably be able to pick out the alterations and mods that make your car almost bulletproof.
I've been running the Kawada 350z. Our club suggests any mini body except for touring car bodies (mazda6, accord) From the feed back I've heard about my car, the 350 is a touring body too. I'm told I'm running a cheater body, it's all in fun but 1/2 way true.
I'm really liking the ABC Porsche body and plan to get it. I just have to clarify if this too, is considered a cheater body at my local tracks.
Old 06-21-2010, 04:56 PM   #161
hanulec's Avatar
first a few pics -
all of my VM2 pics at http://picasaweb.google.com/racerlog/AtomicVM2
Old 06-21-2010, 06:33 PM   #162
hanulec's Avatar
after looking over my VM2 one more time I see the following modifications:
A. Upper suspension links (each)
1- XRay 302664 - T2 Ball Joint 5mm Unidirectional ; these are the parts with the 'dot' on them. i've used them on the inside upper camber links.
1- Team Associated TC5 Short (height) ball studs - 8mm or 10mm length (cannot remember) for use at the c-hub or rear hub
1- 3mm set screw - unknown length - to replace the turnbuckle
1- Team Associated ASC7230 T4/B3/T3 BALL END CUPS (12) - i cut these ball ends in order to make the link short enough to put 1-2 degrees of negative camber into the suspension. i rather cut these ends as they are cheap compared to the xray ones.
B. Steering Links (each)
1- Team Associated TC5 Short (height) ball studs - 5mm for use at the the steering knuckle
1- Team Associated ASC7230 T4/B3/T3 BALL END CUPS (12) - at the steering knuckle
1- kit turnbuckle
1- kit rod end
C. Shocks
1- 3mm x 10mm (i think) cap head screw to replace the grub screws holding the bottom on the shock ends to the lower suspension car
D. Front Spool
2 - XRay 305135 - T2'008 Composite Solid Axle Driveshaft Adapters (2) - to replace the Atomic Stock Units
E. Rear Diff
1 - XRay 34tooth diff from my old T2'008 - only swapped this unit in after the kit original diff screw broke
Old 06-22-2010, 12:07 AM   #163
Mark G.'s Avatar
Default For Sale Atomic VM II
For interested parties, a stock ready to race rolling chassis.
I will include extra output shafts, left and rear arms and original wheels that came with the kit.
Freight included within the Continental U.S.
Price $185
If you have questions please PM me for further details.
Atomic VM2 M-Class Chassis-img_6665.jpg   Atomic VM2 M-Class Chassis-img_6667.jpg   Atomic VM2 M-Class Chassis-img_6670.jpg
Mark G. is offline   Reply With Quote
Old 08-10-2010, 07:53 AM   #164
Originally Posted by MikeXray View Post
Are there any good 210mm bodies that don't end up $40 shipped? is their gold molded into these things?
The Gold was molded into the shipping costs not the body. The bodies themselves are $21 only. SPR007-M6R and SPR002-M6R.
Dealer Xing is offline   Reply With Quote
Old 09-17-2010, 04:33 PM   #165
Acting Bad's Avatar
Which Tamiya shocks will work with the Atomic VMll?
Novarossi engines, Radiopost, Serpent 811 Cobra, Serpent 977 Viper, IGT Hobbies
Acting Bad is offline   Reply With Quote
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9055 02-23-2017 03:26 PM
M Chassis Conversion Kit For TT01-E & TT01 evanwest94 Electric On-Road 99 11-10-2013 01:18 AM
Electric on road dameetz Brunei R/C Racers 195 05-13-2011 07:42 PM
1/12 Touring Cars TommyBlazin Electric On-Road 20 05-07-2009 10:00 AM
