Does Shock Oil Go Bad?
Yes shock oil does go bad but not quickly becuase most oils are silicone. Most of the time the oil becomes contaminated and dirty long before the oil breaks down. But since your oil is still in the bottle, it should be good to go. So the oil in shocks should be changed with use not so much with age.
Not sure if it goes bad in the bottle but I had some 40wt trinity silicone oil in the shocks of an old tamiya I have and when I changed it it after 9 years it was sludge. It must have turned into 80wt ahaha
If it seems to thick for the wt it is then more likely its trash.
