Power Wire Length?
#31
i was also told electricity flows from neg to pos in a class i took some time ago
both wires are part of 1 circuit and since 1 has to be longer it doesnt matter which
and try to find the resistance of a piece of wire i dont know how expensive a meter you have to get before you would actually get a reading but its going to cost a whole lot
my xxx-s has a short pos wire why? because thats how i assembled my battery packs
and im pretty sure when wiring a car amp you try for a short ground because the wire picks up interference compromising sound quality
#32
And since the change in total loop resistance is so small compared to the loop components (motor arm, ESC) it's not worth worrying about.
-dave
#33
Put 50 amps though 6 inches of tyical RC power wire, and measure the voltage drop... You can easily measure it, with any digital volt meter.
I've done tests on a dyno, where I added about 6 inches of wire in line with the motor... I forget exacly how much power loss there was, but it is deffintely noticable, say like 3 to 5 watts if memory serves me...
The resistance of the wire, is a factor, and often it's as much or more then your ESC's internal resistance...
I'll try and do some more tests soon and give actual numbers... but trust me... reducing wire length to a minimum is the cheapest way to increase power you'll ever find in RC.
#35
I just recently obtained a Eagle Tree RC car data recorder, with a electric expander. I can now measure current pretty accuratly as a result.... It should be a realitvely simple thing to measure the voltage drop across a known lenght of wire. Knowing the voltage drop, and the current, we can then caluclate power loss due to wire length.
Stock motors draw less current then, 19 turn motors, and sub 10 turn draw even more current... so, power loss due to voltage loss in wiring, will effect racers differntly depending on what class they run.
Anyway... I'll try to do some testing soon and give some actual numbers from testing.
#36
Your average stock motor will pull somewhere around 25A during a race. If we figure that motor is at an average of 3/4 throttle (~5.3V) throughout the race, we get an average power to the motor of 132.5W being consumed by the motor. Your 6" of wire in that case (0.0008R, 25A) will be dissipating about 0.5W, a grand total of 0.377% of the total fed to the motor. RC motors are arount 50-60% efficient once they warm up. You can see where I'm going with this I think.
As to the best way to go faster, it's to drive better. Those 40mV and 2W are lost in the noise once you sideswipe another car, or tag a board, or tak the wrong line.
As far as testing for losses, attempting to measure the current via voltage drop in an RC car is a longshot at best. I've been through this before. I spent quite a while instrumenting my XXX-S with current and voltage probes, and the current measurements via volatge drop were a disaster. There's way too much noise (ESC and motor induced) to do it successfully and repeatably. I ended up using some very nice (custom) hall effect current sesors from Allegro to get linear, precise, repeatable, accurate measurements of current, and some very nice differential ADCs to grab the volatge data (to two or three decimal places on each). I was working on a stock motor powered car, and the current was well below 50A, more like 25-30 over time.
Losses attributable to wiring (tiny), motor inefficiency (huge), and setup (gear choice, tires, etc, also huge) were all miniscule compared to the variations in the power profile caused by imperfect driving. When you crash, the current draw can exceed 150A for a split second as your motor stalls at full speed. The batteries take a while to recover form that kind of draw, as it messes with their internal chemistry. When you tag a board or another car, the power you spend getting back onto your racing line is significant, as it usually takes more than a second or two of recovery to make it happen. The numbers for my car are probably the most accurate taken outside the test labs at places like Novak and LRP.
Yes, there are losses in wire.
No, they don't matter like people say.
Unless you can drive a perfect line for an entire race, never passing, avoiding, changing lines, hitting anything, or slowing down, you have other things to fix first.
-dave
#37
Well I don't really disagree with what you've said dpaton...
I did a quick test, the quickest I could easily proform.... Using my T35 discharging at 30 amps, I added a 9" peice of 12G Wet Noodle wire. Using my Fluke multi meter, I measured 40 mV across the 9" of wire while the 30 amps was flowing though it...
Using Ohm's law and all that, the numers come out pretty darn close to those you've given. I get .000148 Ohms per inch for my 12 guage Wet Noodle wire..
The numbers I gave previously were from memory of a test I did about 2 or 3 years ago.... Sorry if I mislead anyone with the numbers I gave in my previous post.
To put all these numbers and comments in a differnt perspective...
Consider that the published specs of a Quantum Competition ESC give .00044 Ohms... 6 inchs of 12G wire has about twice the resistance of a high quality ESC. ESC cost $150... Reducing wire length $0.
Typical 1.165- 1.169 six sell pack of GP-3300 $50, typical 1.170+ six cell pack $70. Price differance of $20. This gives you roughly the same increase in voltage as you'd see from eliminating 6 inches of 12 Gauge wire. Cost of 4 packs per seaon, $80... Cost of reducing your wire length $0.
Cost of all your RC equipment? $1000+ .... running the perfect race, and winning by .1 second over second place because you had six inches less wire in your car... Priceless...
Leave your wires as long as you want.... I don't care.
#38
Regarding your battery upgrade comparison, that's really not a fair thing to do, since the higher voltage batteries typically also have lower IR, making you faster for a combination of reasons. Picking the same volatge cells with lower IR will cancel out the wire, but unpredictably. There's so much that's dependent on cell characteristics that I kept it out of this discussion on purpose. A little bit here or there can totally negate these last few posts.
With the reserve power available in today's batteries (I stuff ~4700mAh into my GP3300 practice packs, and can't get them to dump until >10 minutes in stock, my 4 cell packs are the same way) I honestly don't think people need to worry nearly as much about fractional percentages now as they did when I started racing, when 1700SCRs were brand new. Really. There's so much reserve energy left, and the races finish so far up on the discharge curve, it's a non issue.
Yes, there are situations where that fraction of a percent will help you win, but those situations are only faced by theoretical racers at the very highest echelons of competition, where every car makes all of it's laps without ever touching another car or a board, or crashing, or getting tweaked, or anything else. In engineering, it would be said that the losses from the wiring are "sufficiently small they can be ignored." That's the official way of saying that there are bigger and better things to worry about, like the internal resistance of your cells (yes, it can make a huge difference) or the shape your motor is in (brush bounce will kill you in a race).
If it makes people sleep better at night knowing they have half an inch less wire on their car than the guy next door, so be it. I'll be the guy at the track with enough wire to wrench on his car comfortably, and I'll be just as fast (driving ability notwithstanding).
Like I said before, yes, there are losses. No, they aren't big enough to worry about. I think both of our numbers bear this out.
-dave
#39
I just keep my wires long enough to work with... I typcaly don't use 12 gauge myself, at least not on anything shorter then about 4 inches, because I don't like how stiff it is...
All of that wonderfull knowelge asside... it's still pretty darn inexpensive to reduce wire length... and I beleive it's a good habbit to get in.
My next test... is to measure the voltage drop across several of my ESCs and/or come up with a way to test them at heavy load... say 50 or 60 amps. I'll let you all know what I find....
#40
-dave
