EZ run gearing
Old 05-17-2009, 08:32 PM
Default EZ run gearing
Just got a new 9t ez run brushless system. I'm not really familiar yet with gearings with a brushless system. What pinion should i use with a stock spur gear on a tc4? Any help would be greatly appreciated.
guilty503 is offline
Old 05-17-2009, 09:35 PM
edwintklee's Avatar
Trader Rating: 23 (96%+)
i suggest you start ratio at 5.5 and gear down words to achieve desired speed....watch out for motor over heat...
edwintklee is offline
Old 05-17-2009, 09:59 PM
Trader Rating: 17 (100%+)
A 32 tooth pinion would get you around 5.6:1. I think that would run pretty hot. If it were mine I would start with a 25 tooth to make sure things stay cool.
burnineyes is offline
Old 05-17-2009, 11:16 PM
Thanks guys. So 25 tooth will be fine and should keep things cool right?
