SOREX tires
#16
Medium B...those were the ones I used.
#17
Matt > thanks for the info.
This tire and insert war is crazy. Wrong insert and the tire is down the drain with your money.
#18
wolf, no, I don't think so. Here, yoke firms, echo red, either sorex, med thin or firm thick, HPI red, green etc. will all work, sometimes one just has a slight advantage.
#20
insert thickness
i have speedmind firm blue inserts that have 6.0mm thickness.
thinking to grind 'em down to 5.5 or 5.0mm to use with sorex or hpi r33 tires.
anyway, how thick are your inserts ?
#21
Re: insert thickness
We use sorex, med traction indoor carpet...but it gets COLD in there. The best deal going I think is to do the combo thing from Speedtechrc.com
#22
Re: Re: insert thickness
Originally posted by _neas_
Sounds like a pick up line to me, "So, hey there...how thick are your inserts?" SLAP!
#24
I`m been using Sorex 24`s -20`s with the yok firm insert & yok rim on a tc-3...., so....
What is the best insert for these tires on ozite?
thanks...
thanks...
#25
We use 24 20's and up...on Ozite here...its a cold surface though...
I use yoke med inserts, but I got some of the sorex tires/inserts from speedtechrc.com. I havent tried them out yet though.
-s
-s
#26
Jeff, have you tried echo reds in that combo? I have tried both, and personally I like the echo a little better because it seems to hold up better.
As I said, also mounted up a set with the think firms from sorex. Have yet to try them.
Speedo
Speedo
#28
I think the echo reds are pretty much the same compound as the HPI's, perform just as well but hold up better.
#29
Sorex for SoCal stock
Wolfman:
Wassup?
Hey, I'm a newbie at SoCal and have been running the Yok firms with Yok med inserts in stock class.
What do you recommend in the Sorex for stock class? 28r with HPI red?
Joe
Wassup?
Joe
#30
Yok > I assume you are running the Yok Sprint Tires right now? That set-up is good and use to be the best tire, but now people are going to the Sorex or Yokomo.
For the Sorex, I have only tried the 36r with HPI Green Insert. I just bought a pair of 32r (Chilly here in SoCal at night) and I have not decided on an insert yet. But I may go with HPI Red, Sorex Medium Thin, or I really want Echo, but the order did not come through. He got everything but the Inserts
In Summet time the 36r were hooked, they are good now, but a cool weather tire is in order.
