How much weight to add?
How do you guys decide how much weight to add to one side of your car or the other?
So far, I don't know of a precise way to check the balance of the car, so I lift the car up with two fingers (one at each end, as close to the middle of the front and rear bumpers as I can tell with the naked eye), to see if the car tilts to one side or the other but I'm sure there's a better way.
Thanks.
Thanks.
Location: Somewhere between raising hell and Amazing Grace
Trader Rating: 38 (100%+)
I use these little guys http://www.teamirsrc.com/irs3020.html
How much weight you will need to add depends on the car and electronics layout.
-rocky b
-rocky b
-rocky b
-rocky b
TCCFM
I had to move the ruler I was balancing the car on back about 10mm the get balance front to rear.
Don't forget, wheelbase settings etc will also effect this (which is the exact reason for wheelbase adjustments)
Skiddins
Skiddins
i understand balancing left to right but wouldnt be best to have a little more weight toward the rear for more grip,and when adding weight when using lipo batteries should weight be added to equal the amount of a standard nimh pack or just enough to ballance the car and keep it light as possible?Ive always wondered if a car is to light it'l effect the grip of the tires.
Skiddins
I actually used two axles to do the same as the first picture on my Tamiya/Penguin TA05. I just pulled out the center screw for the front bumper, and used an existing center screw hole in the rear. Then I sat the car on the threaded ends of the axles. It wasn't really easy cause the axles kept falling over, but it did work. I found that on this car it was actually the electronics side that was too light...
Talk about ghetto.
Talk about ghetto.
Thanks for all the help. These are all good ideas and have given me an idea of my own. Those items are difficult for me to get plus the chassis I am trying to balance don't have dedicated holes for this purpose. It does however have screw holes along the centre line for things like the bumpers so I think I'm going to remove the countersunk screws and put in some caphead screws and see if I can balance them between the screw heads. If the COG is somewhere between the 4mm width of these screw heads, that's close enough for me
Thanks again.
Thanks again.
