Old 02-09-2002, 04:47 AM   #1
Alvin's Avatar
Default Dyno related questions...
Dear all,
Let's say I have an adjustable endbell motor to dyno. If the timing is set at 0 degrees it should draw a certain amount of current correct?
If I were to increase the timing, the RPM and current should increase, correct?
Is there a point in time after which I keep increasing the timing the current draw and RPM will drop? Or simply not increase?
I need the above info for a small project thanks!
Alvin is offline   Reply With Quote
Old 02-09-2002, 09:04 AM   #2
Yes, 44 degrees along time ago stock motors timing had gotten to this point.
patcollins is offline   Reply With Quote
Rustler ESC related questions karim18 Electric Off-Road 3 08-12-2007 08:59 PM
Questions related to Novarossi N12LL5 engines... cypoh Malaysian R/C Racers 0 02-16-2007 11:25 AM
Any questions related to Durarax Warhead. IhaveWarhead Monster Trucks 4 09-28-2006 09:15 PM
dyno related question pinggoy Electric On-Road 5 04-26-2006 11:25 AM
Radio related questions klw1001 Rookie Zone 8 02-17-2004 10:14 PM
SEO by vBSEO 3.5.0
