Thinking of another EP Touring Car...
I am thinking of another touring car to get. It will be used in both stock and mod classes on a tight high bite carpet track for winter, then moved onto the Asphalt for summer. It might also make a showing on a large asphalt track. Anyone have any ideas? Quantum 2, XXtra, and most likely a d5 will be used...
Warpspeed Demon :)
WHy would you get anything but a TC3?
I suggest Either, X-ray, Or xxx-s, Or might just wait until Results for Mi2 Looks like a neat car. The tc3 is good but it has torque steering....
Originally posted by mike fleming WHy would you get anything but a TC3? |
Yep
Try Waiting for PRo4 seems really really Nice On the cude i dont kno Much about the Car heh..
unanimous
Should you ask, when that little voice in your head says
MISSION 2,MISSION 2,MISSION 2,MISSION 2,MISSION 2,do it,do it, do it,do it,MISSION 2,MISSION 2, ,:MISSION 2,:nod: |
'Cuda or Pro4 :D
x-ray
x-ray t1R or a evo 2 x-ray
Cen all the way!!
which car?
seeing how you stated you will be running on both carpet and asphalt i would say the xray. its an awsome asphalt car seeing how it was designed for asphalt and it is only going to get better on carpet now josh cyrul is on board. and dont get caught up in the shaft vs belt i have run both and see no advantage of the shaft especially in mod. plus the quality of the parts on the xray are no comparison to other cars it is truely a beautiful car it makes most other cars look like toys this one looks like a race car if you get a chance to really look one over you will see what i mean hope this helps a little more than just" this car or that car"
by the way i think having the baats 3by3 and motor in the center really makes this car drive consistant and smooth and that is what wins races jesse :nod: |
STD answer: get the car that are most common at your track, and your local hobbydealer support.. all cars are good today, so it doesnt matter what car you choose to drive. I personally prefer the X Rays becasuse of the high quality and the great handling. (and they are bulletproof to:nod: )
everybody have their preferences, so you'll get a lot of biased opinions.... so listen to "Hatebreed". Also look for an car which is easy to work on...
Originally posted by Cole Trickle everybody have their preferences, so you'll get a lot of biased opinions.... so listen to "Hatebreed". Also look for an car which is easy to work on... hands down maintenance KING.diff adjustment in 2 secs,without screw removal.beat that.hardly ever bad diffs.Externally adjustable damping without shock rebuild. i can go on....but it'll start to sound like a biased opinion now... |
Ok heres what I would go with...
Now im not going to say it but I will give you a hint.... Its based off a car that starts with 'TC' and ends with '3' And the chassis starts with 'Warp' and ends with 'speed'...I would suggest the one that starts with 'Dem' and ends with 'on 1' yea! warpspeed all the way!:sneaky: :D :nod: |
