i need help in soldering loose GP3300 together
it is my first time to solder loose cells together and i need help! (please)
i just recently bought some GP3300 loose cells. and i have got that special holding case for the cells. all i need is some tips on how to get the best out of my cells.
so if anyone can help me to give me a few tips it would be gr8.
thanx
thanx
Pro match site
Here is a good tutorial on how to do it. Make sure you are using a hot enough iron with at least a 1/4 inch tip. and never hold the iron on the cell for more than 3 seconds. Let the cell cool well before trying to resolder if ya make a mistake. Make sure the ends are clean after you sand them. Try to get help putting pressure on the bar as you solder, This not only makes it easier but putting pressure on the bar as you solder helps transfer heat quicker. When you do the final solder it should look like a shiny puddle on top of the bar. Hold the solder in one hand and the iron in the other and feed some solder as your doing the joint remember to be quick.
ok to add:
try to sand the terminals so that the solder will stick.
it's best if u have bars that are made for GP or u can get anyone and bend them first so that they fit perfectly when u rest them on the cells.
I hope u have a battery jig...otherwise it's wise to run out and buy one NOW.
The key is,
1. Hot soldering iron with a big tip
2. Deans Speed Jig
3. tin the surface before solding on the bars.
Once you get the hang of it, its really easy. You do have to be careful not to over solder or leave the soldering tips on the cell too long. Hope this help. If not, you can email: [email protected]
Dan
2. Deans Speed Jig
Dan
Originally posted by SpeediePHATT
Pro match site
Pro match site
btw: Does anybody know if they're selling the new cells? Mabey they're having all those sales to get rid of the old ones?
I can guraantee that anything you get from Pro Match is top quality They have been the leader in the industry for a while now. The sales I saw were for lower voltage cells they probably just have alot of them in stock.
The seem to have sales on everything except the 1.17+ cells which are out of stock. That could mean two things, that they got the new cells, which in general have a lower voltage than the old cells, or that they're trying to get rid of the old cells. I think Ill just order them, I probably wont notice the diffrence anyway.
Originally posted by AE Racer
Do they do it that way if you have them assemble a pack for you? Im pretty new to electric and not great with the soldering iron. I like to do everything myself, but I dont want to chance it with expensive cells. Can anybody vouch for them doing a good job?
all i did is i went on ebay america and australian and just searched for batteries. and sure enough i found a seller. you should try the same thing and if u don't get anywhere ask around at ur club ( ask the experenced guys ) for help where to get the batteries from and usualy they will help u alot.
but one thing don't go to a hobby shop and ask them because 8/10 times they don't even have a cule what they are talking about.
thats all foks.
