Old 04-26-2009, 02:40 PM   #1
Default servo issue
I hooked up a 6v servo to a 6v d/c power pack and the servo arm only travels 5-10 degrees when I push the power button. I need it to travel 90 degrees and stop. Any ideas?
hardwareman` is offline   Reply With Quote
Old 04-26-2009, 03:39 PM   #2
Trips's Avatar
Trader Rating: 16 (100%+)
Servos don't work that way. They move to whatever position the signal tells them to. If you're just attaching it to a 6V power source, it's not getting any positional signal. It will jerk briefly as it gets power, then just sit there waiting for a position signal.
If you're not using it with a transmitter and receiver, then the signal has to come from somewhere else... you could use a "servo tester" (also known as a "servo cycler") for that purpose. It is a small box with a knob on it. You plug the servo in to it, and the servo's output arm follows to movement of the knob on the box.
Trips is offline   Reply With Quote
Old 04-27-2009, 11:02 AM   #3
G_Man's Avatar
Just want to know.. Can a servo be powered from different source? as long as the signal wire is plugged into the receiver?
G_Man is offline   Reply With Quote
Old 04-27-2009, 12:16 PM   #4
MiCk B's Avatar
Either test the sevo in the car.
Or you need something like this:
Test your motor system without using a transmitter and receiver. The SerCon can be used to test servos and throttle control on ESC's.
* Manual mode: turn the knob with different speed, check the reaction time.
* Neutral mode: make the servo go back to the neutral point.
* Automatic 'window wiper' mode: Servo swings like 'window wipers' to their full angles.
* Connect up to 1-3 servos simultaneously
* Test 1-3 servos consistency.
* Connect 1-3 ESC's & test and compare reaction time respectively.
* Connect 3 servos of the CCPM helicopters and select servos.
MiCk B. :-)
MiCk B is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13244 01-31-2016 07:36 PM
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 08:43 AM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 01:50 PM
Another servo in this losi TTR:EB4 Nitro Off-Road 39 03-22-2009 05:36 PM
brake issue on Mtx-4 or Mtx-4R? JRGTR Nitro On-Road 14 02-02-2008 08:31 AM
XRAY T2 : Space Issue butrflynlambie Electric On-Road 23 06-01-2006 12:31 PM
SERVO TLO333 Rookie Zone 8 02-19-2006 07:19 PM
SEO by vBSEO 3.5.0
