Yokomo SD-010FH anyone got an extra set??
I am looking for a set of these yokomo hardened front universal shaft sets. Anyone got an extra set they could sell??
Think ebay has them, wondering if it had stock cause i ordered one a year ago.
anyway wondering why they discontinued the FH, its quite reliable.
None on ebay, everyone is out of sock, it has been discontinued by yokomo. They were very long lasting but did have a problem with the pins coming out and that is why they were discontinued. To bad, I always just put alittle solder over each end of the pin and had very few problems with the pin.
Thanks for the replies.. I am running them in a rayspeed SD, I want to use it for drifting. What would be the strongest CVDs available?? I have the rear hardened SD-010RH. Would be nice to get the front to match
Are Rayspeeds really tough? I want something that will last long. How much would you want for the set front and rear? Would it be ok to run Rayspeeds in the front and the Hardened SD-010RH in the rear?
Can I use a TA05 Spur gear with my 30t aluminum yok pinion??
