Car problems
Old 04-25-2009, 07:00 PM
Trader Rating: 102 (100%+)
Default Car problems
Just installed novak 21.5 blushless motor and havok esc in my jrx-s type r. when i turn on the radio and the car it starts to move foward and if i push the trigger on the control foward the car speeds up if i pull the trigger the car brakes I have a JR xr2i radio and an old JR receiver.
slyfinger1 is offline
Old 04-25-2009, 07:02 PM
Did you set the speed contorl?
jrick78 is offline
Old 04-25-2009, 07:04 PM
Trader Rating: 23 (100%+)
simply all you have to do is read your manual and reverse the throttle on the controller very easy. for the car moving forward just adjust the throttle trim on the left side of the steering wheel if the wheel if pointed towards you, to the correct direction.
not home is offline
Old 04-25-2009, 07:45 PM
Thanks the radio is now working by pull power and forward brake but car car is still moving when the car and radio is on with the trigger not pulled?
Old 04-25-2009, 09:36 PM
simply just hit the switch on the left side of your steering wheel one way or the other until the car is to a complete stop.
not home is offline
Old 04-26-2009, 06:13 AM
Default Thanks
Everything works great now!
