14 guage wire on a lrp sphere ? ok??
can i use 14 guage wire as opposed to 13 that is speced with it.
My local lhs does not have any 13 so i have to go with 14g. Used to be mostly 14 for racing. Will it put too much resistance on the speedo? Thanks, fat:nod: the current wires are too short so I need to change. |
You will be fine with the 14g:nod:
what motor class are you running ?
You might even be fine with smaller 16ga wire depending on the motor and class.
If you are running 1/12, World GT 200mm Pan Car, Stock 2wd Buggy or Truck, 16ga wire will be more than adequate, also saving you some weight. |
ssoldered up the 14. Thanks for the help, close thread thanks.
