GM V12 question about cap.
I have a used V12 with no paperwork and I needed to know where the barrel capacitor leads get soldered to on the esc?:confused:
The wire coming from the gray strip(Neg) goes to the "Battery -" tab. The other wire goes to the "M/B +" tab. Neither wire should contact the center tab.
I hope this is what you needed. PM me your email address, and I can send you the V12 Manual. Its a .pdf file so you will need Adobe Acrobat reader though. |
Thanks buddy!
No problem. Someone gave me the file when I got my V12 used. Its only right to do the same for someone else.:tire: :spidey: :tire:
