Old 11-22-2010, 07:22 AM   #1456
SteveM's Avatar
Trader Rating: 140 (100%+)
Is anyone using the optional Tamiya (#84150) TA05-VDF Ackerman steering set in their TA-05?
SteveM is offline   Reply With Quote
Old 11-22-2010, 08:21 AM   #1457
Firefox's Avatar
Anyone know what the "empty", no tires/wheels, no servo, no esc, no motor, no body, no battery, weight of the TA-05 ( any version ) is ? Grams, OZ, doesn't matter. With or without aluminum up grades.
thanks
Firefox is offline   Reply With Quote
Old 11-26-2010, 10:38 AM   #1458
Trader Rating: 30 (97%+)
need help, does the original ta05 bumper parts fit the version 2, as i like the option of different mounting positions, so just wanted to know if the bottom piece will work of if any one has tried it thanks
zaraz is offline   Reply With Quote
Old 11-26-2010, 05:23 PM   #1459
94eg!'s Avatar
Trader Rating: 17 (100%+)
That would never fit a TA05. It's almost twice as wide as the TA05 steering bridge...
94eg! is offline   Reply With Quote
Old 11-26-2010, 06:13 PM   #1460
SpeedChair's Avatar
Trader Rating: 15 (100%+)
Hi all, just getting back into RC after 3 years; just picked up TA05 V2-R, does anyone have setup recommendations for Tamiya track in Aliso Viejo? Any help is appreciated, looking forward to running the car soon.
So far, have installed the Speed Passion Citrix esc/brushless combo. Still need body, and tires.
Is the V2R the same as V2, but with more bling bling?
Thanks !!
SpeedChair is offline   Reply With Quote
Old 11-26-2010, 06:49 PM   #1461
SteveM's Avatar
Tamiya (#84150) TA05-VDF Ackerman Steering Set
Old 11-26-2010, 07:08 PM   #1462
anybody
Old 11-27-2010, 08:18 PM   #1463
Zac_with_no_K's Avatar
Questions??
Does anyone know exactly what peice I'm supposed to cut down for the stabalizer set?
I'm confused at the directions..
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Zac_with_no_K is offline   Reply With Quote
Old 11-27-2010, 09:31 PM   #1464
bl4
bl4's Avatar
Does anyone here have the format calucation for the
Final Drive Ratio
Gear Ratio (internal gear ratio)
Thks
bl4 is offline   Reply With Quote
Old 11-27-2010, 11:20 PM   #1465
nope it won't fit. the original up to the ifs-r is much wider. the v2 and v2-r uses the tb03 bumper
platypus_s13 is offline   Reply With Quote
Old 11-27-2010, 11:22 PM   #1466
the vdf is a limited run drift edition that has a completely different config. it won't just bolt on.
Old 11-27-2010, 11:26 PM   #1467
Final Drive Ratio
Thks
a simple google search would have given you this info:
primary ratio:
Primary Ratio = spur / pinion
internal gear ratio:
Internal (belt) = differential pulley/ center pulley
Internal (shaft) = differential gear/ shaft output gear
final drive ratio:
Final Drive Ratio = Primary x Internal
Old 11-29-2010, 06:22 AM   #1468
bl4
bl4's Avatar
Smile
primary ratio:
final drive ratio:
thank you for the info
Old 11-29-2010, 06:22 AM   #1469
bl4
bl4's Avatar
Smile
primary ratio:
final drive ratio:
Old 11-29-2010, 06:00 PM   #1470
reenmachine's Avatar
Trader Rating: 26 (100%+)
My IFS-R is getting a little tired, and I also want a new body. Rather than buying the parts I need, I'm considering buying a standard ver.2 kit and swapping all/most of my "R" parts over to it.
What won't fit?
I know the TRF shocks and short lightweight suspension arms will, but what about the following?
- 46mm universals
- suspension blocks (non-split)
- belts
- various aluminum and titanium turnbuckles (steering and suspension)
- spool
Thanks in advance!
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 10:20 PM
