Old 11-08-2010, 06:39 PM   #1411
Do you carry the center one-way for the Ver II?
Originally Posted by stitchy View Post
v2-R's are in! Those who sent pre-orders will have theirs shipped out today!
outlandr91 is offline   Reply With Quote
Old 11-10-2010, 11:26 PM   #1412
Hi Guys,
I would like to know what is the advantage of having 46mm swing shaft instead of 44mm?
hansenhon is offline   Reply With Quote
Old 11-10-2010, 11:52 PM   #1413
stitchy's Avatar
sent you a PM
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 11-11-2010, 05:02 AM   #1414
slakr's Avatar
Trader Rating: 25 (100%+)
Originally Posted by hansenhon View Post
Hi Guys,
I will comment what I think, but I hope that someone else will respond as well and/or please get a second opinion...
I believe that with the "stock" kit supplied arms the 46mm swing shafts are needed. However, if you switch to the 416 "short reversible" suspension arms you need the 44mm swing shafts.
AE B6D,TC7|Mugen MBX7TR Eco|JQ THE Car WE,eCar WE
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 11-11-2010, 07:53 AM   #1415
hi, thanks..
just did a check on my TA05 ver.II R kit... The kit supplied with 44mm rear and 46mm front..
Old 11-11-2010, 08:14 AM   #1416
slakr's Avatar
I have the original V2 and have 46mm swing shafts front (51092) and rear (53724). I am using the kit arms and a spool up front.
I also have the new V2R, but haven't put it together... yet
I will be using a spool up front on the R as well
Old 11-11-2010, 08:30 AM   #1417
LOL.. me too... got it more than 2 weeks already... but too busy to put it up together... I would try the kit supplied ball-diff first.... then will try front one-way
looking to put on with new Raybrig HSV-010... still waiting for it available
Old 11-11-2010, 01:27 PM   #1418
portyansky's Avatar
Trader Rating: 53 (100%+)
Are aluminum uprights needed? Or should i just buy a few sets since they are only like $3 for a set? I saw Hot Racing sells them for like $14 (no tcs for me).
Team Tekno Canadian Team Manager
Team Hitec
portyansky is offline   Reply With Quote
Old 11-11-2010, 02:46 PM   #1419
slakr's Avatar
Been racing the stock uprights last carpet season, outdoor asphalt & now back indoors for carpet again... haven't broken one yet
Old 11-11-2010, 06:12 PM   #1420
Back at ya
sent you a PM
Old 11-12-2010, 06:17 AM   #1421
well... those stock carbon reinforced uprights are good enough for me... thats just me...
Old 11-13-2010, 07:49 PM   #1422
Zac_with_no_K's Avatar
Questions??
I can't find any 3x28 turnbuckle shafts.. will 3x32 work? (For Tamiyas 5mm turnbuckle ends)
I did find 3x23 but I don't see these on the kits manual??
would these work better instead?
I' hopeing the 3x32 will work on everything because the blue aluminum ones are a lot cheaper!
If the 3x32 will work for most of the turnbuckles I want to stock up on them..
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Zac_with_no_K is offline   Reply With Quote
Old 11-13-2010, 08:40 PM   #1423
Questions??
Another question..
If I get the TRF damper set. What spings work best? or is there a spring set I can get?
And what do you think the best damper oil would be?
I run on a medium size carpet track with 13.5 motor
Thanks.
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Old 11-13-2010, 08:50 PM   #1424
Questions?? SORRY another..
Will this work for the front hub carriers?
http://www.speedtechrc.com/store/ebp...id=665&id=7520
It's a 3racing TA05 one.. I don't see a hole for the grub screw though?
If I get these will I need to make a lot of adjustments?
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Old 11-14-2010, 05:32 AM   #1425
Zak,
Check out Lunsfordracing.com. The titanium turnbuckles are light and much stronger than aluminum. If you call them, you can order just the turnbuckles without the end caps. I also got titanium suspension hing pins from them. They are for a different car so I had to shorten them a bit but they work great and are much lighter.
woodys3b is offline   Reply With Quote
Electric Touring / On-Road RC Screaming Wind Manila Racers 32165 10-24-2016 10:33 PM
SEO by vBSEO 3.5.0
