Old 10-25-2010, 12:39 AM   #1366
RC Passion's Avatar
Originally Posted by DuckStang View Post
Spur is 70, pinion is at 20 right now. Internal gear ratio is at 2.055(counting diffs and center gears attached to the shaft that attaches to the spur)
Right now i am running a 7.1925FDR. Speed passion 17.5 and stock club esc. I just don't want to burn anything up. Will I be OK???
If you're talkng about 48 pitch and 2.055 internal ratio, I'd go way up on the pinion at least 32 tooth! Around 4.5 FDR would be a good starting point. Then gear to your speed/driving comfort level and temp.
RC Passion is offline   Reply With Quote
Old 10-25-2010, 09:14 AM   #1367
Trader Rating: 14 (100%+)
Holy snap!!! Did not even think they made a 32 tooth pinion. I will give it a try and report back. I was thinking I had to go the other way, like a 10:1 FDR. I had it wrong.
DuckStang is offline   Reply With Quote
Old 10-25-2010, 12:08 PM   #1368
Send a message via AIM to liquidgenesis Send a message via Yahoo to liquidgenesis
Duckstang, if you're using the Tamiya 70T Spur, then it is NOT 48p like most people will lead you to believe. Stock Tamiya uses the AV pinion set which has bigger teeth than 48p. 0.6metric pitch is closer to 48p but even then it will run choppy. I have 26T pinion for all three pitches and the Tamiya AV pinion is roughly 1mm in diameter larger than the 0.6mod or the 48p. the 0.6mod is <.5mm larger than the 48p. Might not seem like much but trust me, its enough to chew up your spur.
Only reason I have a 48p pinion is because of my blitz. Went through 3 spurs in as many months using tamiya pinions before finally getting a 48p.. 8 months of constant bashing and the spur shows no signs of wear now, even with it being wobbly(common blitz design flaw).
If you want your spur to last more than a few months of running, then stick with tamiya AV pinions or upgrade to 48p spur and pinion to get more gearing options. Or better yet 64p and run ultra smoother and even more gearing options.
TA01 - TA02W - TA03F PRO - TA03R - TA05 - TA05R - TA05 IFSR - TA06 PRO - FF03 PRO - F201 TUNED - F103GT - DF03 - F350 High Lift - CC01 - BERG Tracer - TRAXXAS Revo 2.5 BL - VENOM GPV-1 - KYOSHO HOR - AQUACRAFT Supervee 27R - PRO BOAT Shockwave 26RS
liquidgenesis is offline   Reply With Quote
Old 10-25-2010, 05:34 PM   #1369
Thanks for the info, liquidgenesis. Will Associated tc3/4 spurs work in the tamiya's?? My LHS carries a whole lot of associated stuff.
Old 10-25-2010, 07:24 PM   #1370
Super Moderator
Grizzbob's Avatar
Yes, & any standard Kimborough spurs will fit perfectly(those are what I've been using for years, they've never let me down)....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 10-25-2010, 08:26 PM   #1371
Zac_with_no_K's Avatar
Wait.. So is it bad to be using a 48p pinion??
I have a 28t pinion with the tamiya stock 70t spur for a 13.5 motor..
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Zac_with_no_K is offline   Reply With Quote
Old 10-25-2010, 11:36 PM   #1372
izzyracer's Avatar
Trader Rating: 27 (100%+)
Is your 28t pinion Tamiya? What he is saying is Tamiya gears are not the same as gear from other manufacturers. They are slightly of different size and will not mesh properly. If you are using a Tamiya spur and pinion then you are fine.
Izzy
izzyracer is offline   Reply With Quote
Old 10-26-2010, 02:01 PM   #1373
I think it's a Robinson pinion.
If it is bad to use this pinion, what damages could this cause?
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Old 10-26-2010, 08:11 PM   #1374
BigRon's Avatar
Send a message via AIM to BigRon
Does anybody have any advice on freeing up the drivetrain? I have worked on the bearings and everything spins free until I attach the belts. I have them at the stock setting. I tried loosening them one notch but the drag is still the same. I'm trying to free up the drivetrain as much as possible. Thanks
*Serpent America*
SRX-2 ~ F110 SF2 ~ S100 LTR
Desoto Racing ~ KO Propo
BigRon is offline   Reply With Quote
Old 10-28-2010, 03:52 AM   #1375
hi all,
i just got my TA05 ver.II R this afternoon.
I would like to check if the TA05 ver.II hop-up (namely aluminum part such as racing steering (tamiya part #53848), etc..) are perfectly usable on the "R" version??
Thank you
hansenhon is offline   Reply With Quote
Old 10-28-2010, 07:58 AM   #1376
Questions??
Do you guys know if theres anywhere that sells seperate Titanium screws(alen wrench heads) not in a pack that costs $70?
I just want to get a couple replacement screws and also get some for back-up.. I already have the set.
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Old 10-28-2010, 05:03 PM   #1377
stitchy's Avatar
We do!
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 10-28-2010, 05:05 PM   #1378
stitchy's Avatar
TA05 V2-R in stock verrrrry sooooooon
Old 10-28-2010, 11:39 PM   #1379
Originally Posted by hansenhon View Post
hi all,
Thank you
i don't see why it wouldn't. it's still the ver.2 just with more bling.
platypus_s13 is offline   Reply With Quote
Old 10-29-2010, 03:48 AM   #1380
slakr's Avatar
Trader Rating: 28 (100%+)
For the original V2 I used the TB03 Alum. Racing Steering Set #54095
JQ THEeCar Black,THECar White~Mugen MBX7TR Eco~TLR 22 3.0SR,22-4 2.0~XRAY XB2C
AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Electric Touring / On-Road RC Screaming Wind Manila Racers 32165 10-24-2016 09:33 PM
