Old 09-22-2010, 11:42 AM   #1246
kdeselms's Avatar
Yeah I'm using a Kimbrough but I might try putting a new one on, just to see if that helps. I have the toe blocks on order, right now I'm just at the original kit setup for front and rear toe...so that will change.
Kevin Deselms
Associated Factory Team SC10
Webmaster, www.hotrodhobbies.com
kdeselms is offline   Reply With Quote
Old 09-22-2010, 01:00 PM   #1247
Zac_with_no_K's Avatar
I have a kimbrough #114 and I'm wondering what hole to use? And I'm guessing it's still supposed to be at 5 degrees when you install it??
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Zac_with_no_K is offline   Reply With Quote
Old 09-22-2010, 07:25 PM   #1248
Trader Rating: 19 (100%+)
Hello gents,
I'm looking for a bulkhead. Details here. Any info is appreciated.
***Proudly supporting The Fist: "Hope everyone improve their lap time. Don't be stubborn."***
R.I.P. Tommy Kraimer, 28 time UK Champion, 4 time JMRCA champion, and engineering mastermind behind the TKX-10. The world will never be the same.
Zaner24 is offline   Reply With Quote
Old 09-23-2010, 01:09 PM   #1249
Another question, I'm at the step where I connect the electronics to make sure the servo is in neutral, and the motor starts spinning without me giving any throttle. (the motor came connected to the ESC without plugs)
What do I do?
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Old 09-23-2010, 02:51 PM   #1250
Nevermind on the motor question, I didn't realize I needed to go through set-up procedures.
I still am confused on attaching the Kimbrough though
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Old 09-23-2010, 04:16 PM   #1251
Zac,
Attach the ball to the servo saver in the hole that is furthest to the outside of the car or furthest to the left. Then allign the ball with the servo as shown in the instructions. If you PM me your e-mail address, I can send you a photo of mine that might help.
woodys3b is offline   Reply With Quote
Old 09-23-2010, 06:39 PM   #1252
Do you need to drill into the Kimbrough to make the ball fit? I have the white one and the holes are too small. If you did drill, what size drill did you use?
Everything's finished in my car except for the electronics(Skipped past that part to finish it up). I'm just trying to decide wether to dremel down the chasis or get different gears. My pinion is too big.
Got pictures if anyone wants to see my almost completed car..
And there's a race tomorrow, but I don't know if I want to drive it on a track without a lot of practice.
I have two Futaba S3003 standard size servos. How do you think they'll do? I'm think going to eventually get a S9551 but these came with the kit as a bundle and I thought they might last me a while and be decent enough.
I wanted to thank all of you that helped me!
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Old 09-23-2010, 07:05 PM   #1253
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
been running with the stock tamiya high torque servo saver with no problems...
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 09-23-2010, 07:24 PM   #1254
I'm going to be using that until I have a problem with it.
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Old 09-23-2010, 07:37 PM   #1255
kdeselms's Avatar
If you hit anything with the front end, you'll find that Tamiya stock servo saver will get "stuck" a little to the left or right and your steering will drift to one side. You'll be riding your steering trim on the track to keep it straight. That was the problem I had with it, that made me go with the Kimbrough.
Kevin Deselms
Old 09-23-2010, 07:44 PM   #1256
superspeed's Avatar
Go with this new release aluminum servo horn - black color.
http://www.tamiyausa.com/product/ite...oduct-id=84082
superspeed is offline   Reply With Quote
Old 09-23-2010, 08:14 PM   #1257
Did you drill a hole to make the ball connecter fit?
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Old 09-23-2010, 08:20 PM   #1258
VooDooPH's Avatar
the stock tamiya servo saver (the black plastic one with the black plastic saver ring) does suck big time.
for the high torque version (3 steel rings) i usually just add a drop of thick CA clue to either side of the steel rings. the CA won't keep stuck with the steel rings in the event of a crash but the CA bonded to the plastic acts like a filler to lessen the side-to-side play.
Old 09-23-2010, 08:52 PM   #1259
Now I need to cut away at the motor mount for this 36 pinion to fit, but don't know if that's a good idea. Already dremelled down a peice of chasis but didn't realize it would touch the motor mount.
Someone recomended 105 tooth 64 pitch spur and pinions between 46-49. earlier(but I wanted to use the kit spur gear) would these fit better or would I need to cut away more to make these fit for the 4.3-4.5 F.D.R.?
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Old 09-23-2010, 09:05 PM   #1260
VooDooPH's Avatar
I'm running a 94T spur with a 43T pinion (64p)... no need to cut or dremel anything...
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 10:20 PM
