Old 09-11-2010, 12:53 AM   #1216
RC Passion's Avatar
Originally Posted by spazmo View Post
I was hoping for some thing more like the TA05MS, but with the V2 short suspension and TRF417 lipo chassis.
Perhaps a V2 MS is still in the works.
Ya think that the TRF417 or any TRF chassis would match up/ be compatible w/ the TA05v.2?
RC Passion is offline   Reply With Quote
Old 09-11-2010, 04:39 AM   #1217
Originally Posted by dragnse7en View Post
Oh - bye the bye - dragnse7en DOES NOT NOR NEVER CRASH. PERIOD.
Just say no......................
woodys3b is offline   Reply With Quote
Old 09-11-2010, 12:38 PM   #1218
spazmo's Avatar
Unfortunately no, TRF417 has different front and rear bulk heads and motor mount to the v2.
You might be able to drill the chassis to mount the bulkheads but there is nowhere on the v2 bulkhead to mount the top deck.
I'm guessing that tamiya will eventually bring out a TRF chassis just have to hurry up and wait.
spazmo is offline   Reply With Quote
Old 09-11-2010, 04:38 PM   #1219
The new TRF417 has TA05MS bulkheads. The ta05ms was a pure TRF developed car. I think Tamiya now only offers 'R' or pro versions of it's club chassis cars.
I think if you want to get a V2 ms then buy the exotech lipo chassis and tamiya hop-ups and you will have a smart looking ride.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 09-13-2010, 07:05 PM   #1220
kdeselms's Avatar
Can anyone tell me if there's an option part for the stabilizer hold-downs to match the aluminum stabilizer mounts? I got the stabilizers and the mounts, however I discovered that the parts the kit documentation said were "not used" - the stays - were actually going to be needed if I added sway bars. So of course, they're long gone.
Kevin Deselms
Associated Factory Team SC10
Webmaster, www.hotrodhobbies.com
kdeselms is offline   Reply With Quote
Old 09-13-2010, 08:36 PM   #1221
Zac_with_no_K's Avatar
I ordered the Novak/ESC and all the parts kdeselms(thanks!) suggested(1 page back) plus a few other things(bushings,titanium screw, e-rings, 4mm alum. wheel nuts, alum. hubs and couple sets of tires).. I got 2 low friction belts and was just wondering what the difference between the low friction belts and the provided white belts from the kit?
I'm hoping all these will get me through a few crashes(which I'm expecting as its been 5 years since I last touched a RC remote)
+1 I would like to eventually get sway bars but don't know what else I would need to purchase.
Zac_with_no_K is offline   Reply With Quote
Old 09-13-2010, 10:43 PM   #1222
kdeselms's Avatar
The low friction belts are stronger and don't stretch out as easily as the white ones, due to the material. As for what you need with the sway bars - you will want to keep the plastic pieces from the kit (sprue B, I think) which I no longer have and am trying to find a replacement for Then you'd want to get aluminum mounts to replace the plastic ones that come with the kit (2x #53916), the sway bar kit (#53844) and the sway bar stoppers (#53827) to keep them from moving left and right in the holders. You don't HAVE to replace the mounts, but I did.
Kevin Deselms
Old 09-14-2010, 05:37 AM   #1223
Trader Rating: 30 (97%+)
hi, i just purchased the porsche 934 ta05 ms, and wanted to know if there was a way to make it 237mm wheelbase from 230mm, as i have some corolla bodies i would like to run, the suspension spacers only allow 3mm, so need another 5mm are there any other tamiya suspension arms i could use to arrive to 237mm wheelbase thanks
zaraz is offline   Reply With Quote
Old 09-14-2010, 11:47 AM   #1224
Yeah I would want to get the aluminum mounts too.
Thanks again!
TA05v.II
Tamiya M-05
SC10 Brushless RTR
Old 09-15-2010, 01:46 PM   #1225
tom_chang79's Avatar
What GT bodies are you all running?
I'm still running my classic HPI Honda Accord body, 1997-style Accord, which was a pain in the butt to find...
I started using RPM's body savers too, since I believe I bought the last one to exist in this world... Unless HPI would like to re-run it...
RIP TAP RC
tom_chang79 is offline   Reply With Quote
Old 09-15-2010, 08:09 PM   #1226
kdeselms's Avatar
My favorite body right now is the 2007 NSX (in either the Raybrig or the Takata Dome livery), until the Raybrig HSV-010 comes out later this year. I also like the EBBRO 350R a lot.
Question for everybody not using the aluminum rocker arms (which I cannot seem to find in stock anywhere on the web, including Tamiya). Is there an option bearing set of four bearings for the regular plastic rocker arms, rather than the copper slugs it comes with? I'd like to put bearings in there. Also, what size shims would I need to get rid of the up/down slop in the rocker arms?
Kevin Deselms
Old 09-15-2010, 09:00 PM   #1227
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
same sized bearings as the one inside the ball diff
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 09-15-2010, 11:20 PM   #1228
Skitee's Avatar
These are the shims you need for the rocker arms.
http://www.tamiyausa.com/product/ite...oduct-id=53587
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 09-15-2010, 11:53 PM   #1229
kdeselms's Avatar
Thanks, guys.
Has anyone used the Exotech replacement chassis? I haven't read many reactions or any reviews, curious if people feel it's worthwhile? I want to stick with the IFS-style shocks, just because I like the low-profile bodies so much, but my tub chassis has a ton of tweak in it and I'm wondering if I'm just stuck having to upgrade to a better car, or if this would solve it.
Kevin Deselms
Old 09-16-2010, 12:02 AM   #1230
VooDooPH's Avatar
Thanks, guys.
building mine at the moment... hope to have its maiden run sometime next week.
Electric Touring / On-Road RC Screaming Wind Manila Racers 32165 10-24-2016 09:33 PM
