Old 08-31-2010, 11:02 PM   #1171
Skitee's Avatar
Most 13.5 motors running without timing advance and boost would be geared in that FDR range.
Yes a new diff should feel smooth, you may get a slightly notchy/scratchy feel if you over tighten the diff screw and damage the thrust bearing.
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 09-01-2010, 12:25 AM   #1172
kdeselms's Avatar
Can anyone tell me if Tamiya makes a 2008 Takata Dome NSX body that sells separately, which I could put on my V2? I have not had any luck in finding one that isn't sold with the TB-03 kit, I don't know if anyone here might have knowledge of where to get 'em?
Kevin Deselms
Associated Factory Team SC10
Webmaster, www.hotrodhobbies.com
kdeselms is offline   Reply With Quote
Old 09-01-2010, 02:17 AM   #1173
spazmo's Avatar
Does any one know if these will fit the V2 chassis, or are these the longer 48mm shafts?
The V2 chassis should be used with 46mm shafts from what I can tell
dub dub dub .yeahracing.com/catalog/ta05015c1bk-steel-universal-shaft-combo-ta05-p-1964.html
spazmo is offline   Reply With Quote
Old 09-04-2010, 02:12 PM   #1174
Zac_with_no_K's Avatar
Unhappy
Sorry to bug you about this again..
I'm still confused about the pinions and gears and don't know what FDR is but I'm hoping to get that 13.5 brushless motor/ESC soon.
I would really like to use the stock black gear if I could.
would any pinions from an even pack of 16-26T pinions work for the 4.3-4.5 FDR with that stock black gear?
Theres also an odd pack 15-25T if that would work better?
Heres a link to the pinions:
h**p://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXEX34&P=M
Zac_with_no_K is offline   Reply With Quote
Old 09-04-2010, 03:02 PM   #1175
spazmo's Avatar
Hi Zac
If you go to this link there are fdr charts for the 416, the 416 has the same final drive ratio as the v2.
Remember the V2 has .6 module gear pitch not the 48 or 64 as in the charts, but you will still be able to get the correct pinion size.
The kit spur is 70T so a 32T pinion will give you a 4.50 FDR.
h**p://rss.rcmart.com/2008/12/31/tamiya-trf416-gear-ratio-list/
The set of pinions from tower hobbies you are looking at is 48 pitch these will not work with the kit spur.
This pinion is the correct 0.6 pitch.
h**p://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXUFL0&P=**Missing%20Data**
I hope this all makes sense!
Old 09-04-2010, 03:10 PM   #1176
spazmo's Avatar
FDR = Final Drive Ratio
This is the ratio that includes all the gears in the car between the motor and the wheels.
In the v2 this includes the ratio between the pinion and spur and the ratio between the belt pulleys on the lay shaft and the diffs.
This may be a little confusing but in full scales cars FDR will often be used just to refer to the ratio found in the diff, or final drive.
Old 09-05-2010, 04:06 PM   #1177
Trader Rating: 29 (97%+)
hi, i just ordered the ta05 ver 2, had a question, the aluminum bulk head, is it just the front, or do you get both the front and the rear in the package thanks, also how does this car handle compared to the 415 msxx mre, if anyone wo has owned both can chime in thanks
zaraz is online now   Reply With Quote
Old 09-05-2010, 10:43 PM   #1178
Skitee's Avatar
The front and rear ally bulkheads do not come together.
Old 09-06-2010, 01:20 AM   #1179
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
just sharing my V2...
will post pix of the EX05 after the local TAC event...
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 09-06-2010, 03:46 AM   #1180
kdeselms's Avatar
Looks like a TA-05 Ver.2-R model is coming later this year...nice!
http://tamiyablog.com/
Kevin Deselms
Old 09-06-2010, 07:58 PM   #1181
does tamiya make a carbon upper and lower deck, but with the ifs on board suspension, as i have ordered all the hopups, but cannot find a carbon upper and lower plate, thanks
Old 09-06-2010, 11:24 PM   #1182
Skitee's Avatar
Tamiya does not make carbon top and bottom decks but EXOTEK does make.
http://www.exotekracing.com/EXOTEK_N...7/12_EX05.html
Old 09-08-2010, 01:42 AM   #1183
kdeselms's Avatar
Mmmm...new TA05 VII kit being announced at the Tokyo Hobby Show. I won't have to run the 2007 Raybrig anymore, I can get the current version
See announcement (among many others) here!
Kevin Deselms
Old 09-08-2010, 03:19 AM   #1184
Azr
Azr's Avatar
Send a message via Yahoo to Azr
the new version of V2?
Azr is offline   Reply With Quote
Old 09-08-2010, 04:48 PM   #1185
kdeselms's Avatar
I attached a picture of the new Version 2-R chassis with the body off. This PDF file has all the details on the parts and options that come with the Version 2-R kit.
53894 = TA05 Carbon Reinforced A Parts
54031 = TA05 IFS Carbon Reinforced F Parts
54196 = TA05 ver. II Carbon reinforced K Parts
53928 = Short Rev. Suspension Arm
51333 = TRF 416 E Parts
51332 = TRF 416 C Parts
53991 = TA05 IFS Reinf. N Parts
51000 = Hi Torque Servo Saver
54145 = TB03 Urethan Bumper
54170 = TA05 ver.II Low Friction Drive Belt 342mm
54078 = 44mm Swing Shafts
54077 = 44mm Lightweight Rear Swing Shaft
54076 = TB-03 Wheel Axles
53500 = Cross Joints for Assembly Universal Shaft Set
54071 = TB-03 Aluminium Suspension Mount 1C
54073 = TB-03 Aluminium Suspension Mount 1E
42102 = TRF Special Damper (Hard Black Coating)
54174 = TA05 ver.II Separate Suspension Mount1C-1XC
54172 = TA05 ver.II Separate Suspension Mount 1A-1XA
Front and rear stabilizers and a new aluminum motor mount (although the one in the picture looks like the same old mount...)
Kevin Deselms
Electric Touring / On-Road RC Screaming Wind Manila Racers 32165 10-24-2016 09:33 PM
