Old 08-03-2010, 08:21 AM   #1111
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Wow a little quiet in here lately. I need to get mine up and running so I can post on how the car is working. I hope to run it in 2 weeks or so for the first time. Still working on fitting my speedo in and getting that body painted and mounted on the car. I need to get in gear.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 08-03-2010, 10:49 AM   #1112
vadersing's Avatar
Dear TA05 v2 guys,
Can anyone advise which powerful lipo batts to buy for my TA05 v2 without modifying the tub?
I have a couple of Nosram 5300 batts but they don't sit flat in the tub.
Need some help please.
vadersing is offline   Reply With Quote
Old 08-03-2010, 10:51 AM   #1113
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by vadersing View Post
Dear TA05 v2 guys,
unfortunately.. you'll be better off modifying the tub so that the battery sits lower and flat. that way you can buy ANY battery and it'll work with your car.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 08-03-2010, 11:04 AM   #1114
vadersing's Avatar
Could you show me how it's done please?
Old 08-03-2010, 11:08 AM   #1115
Hebiki's Avatar
i use a dremel tool to remove the bumps. one is a cutting tool, the other is a cutting disc. i leave the inner fence to keep the battery from hitting the belts.
Hebiki Design Works
Old 08-03-2010, 12:38 PM   #1116
rc_square24's Avatar
I have a TA-05 running with short reversible arms front and rear, 37/18 pulleys. If I get the V2 motor mount assembly, 46mm sus. shafts and possibly the lower suspension arm mounts for F/R will I be able to use the Exotek chassis kit?
Thanks!
rc_square24 is offline   Reply With Quote
Old 08-03-2010, 01:53 PM   #1117
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Thanks!
you also need the K-parts from the V2 chassis to mount the front shocks.....also for the motor mount you need all the parts that go with it...ie the Layshaft, spur gear mount and the little stopper on the end of the layshaft. Also if it uses the V2 steering rack you need to get the one for the TB03 as its the same as the V2/TB03 and the TA05 non-v2 will not work.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 08-04-2010, 02:46 PM   #1118
over gear's Avatar
Trader Rating: 15 (100%+)
my Exotek chassis
before:
chassis width compared:
almost ready:
over gear is offline   Reply With Quote
Old 08-04-2010, 08:41 PM   #1119
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
Originally Posted by over gear View Post
my Exotek chassis
before:
almost ready:
nice! can't wait till mine arrives next week
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 08-04-2010, 10:54 PM   #1120
So the tamiya & 3racing aluminum bulkheads i have now will fit on the v2/exotek chassis i assume, i can run the front shocks in stand-up position like I have now without the k-parts (rocker) right?
will the 4 tamiya aluminum lower arm mounts i have now for the v1 fit on the v2? is it just a difference of shaft length (46/49.7)or are mounting holes different too?
Thanks a lot
Old 08-04-2010, 10:59 PM   #1121
JD Skyline's Avatar
my Exotek chassis
almost ready:
AWESOME!!!!!! This looks great!!!!!! When you start racing with this chassis please give me some info about it
I,m going to order it as well!!!
JD Skyline
"NO GUTS NO GLORY"
Tamiya TRF418, Tamiya TT-01 Type E and Still lookin'for more Tamiya cars.......
http://jdskyline.blogspot.com/
JD Skyline is offline   Reply With Quote
Old 08-05-2010, 07:31 AM   #1122
Kevin K's Avatar
Thanks a lot
Yes the bulkheads should just bolt right on. Stand up shocks sure you should be able to do that. You will still need the K-parts for the front chassis brace even if you dont use the lay-down shocks.
You are correct....the V1 arm mounts will work on the this chassis you just need the shorter hinge pins. If you look a the pictures just posted you will see hes using the old arm mounts on the new Exotek chassis.
Old 08-05-2010, 12:04 PM   #1123
over gear's Avatar
i'm using the suspension mounts from 415. they are old.... u will need new hinge pins. the TA05 V1 is 50mm long. the V2 is 46mm long.
you can use the standard stand-up front suspension... but you will still need the V2 K-part tree. The top deck from Exotek goes from the rear bulkhead to the motor mount then to the steering post. you need the part from the steering post to the front bulkhead.
Mike from Exotek said he'll have a long top deck that connects from bulkhead to bulkhead soon .
testing at the Tamiya track this Saturday.
Old 08-07-2010, 05:53 PM   #1124
over gear's Avatar
just got back testing the Exotek chassis at the Tamiya track... compare to the tub chassis... the exotek is much much more stable everywhere. i didn't clock the lap time, but i know i'm faster with the same equiptment and tires. i now have more confident driving the car deeper into the corner. i can also ride the curb higher without flipping. i guess the much narrower chassis did the trick. all in all, i'm very happy with the new chassis
Old 08-07-2010, 07:41 PM   #1125
Can you get some actual lap times? It would be interesting to compare.
outlandr91 is offline   Reply With Quote
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 10:20 PM
