Old 07-25-2009, 12:06 PM   #91
JimmyMac's Avatar
Originally Posted by redbones View Post
Is that what the extra holes by the suspension mounts are for?
Yeah.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 07-25-2009, 12:16 PM   #92
Skitee's Avatar
Originally Posted by bl4 View Post
Thks Bro! Can this be use for ver.2 53871 48mm lightweight rear swing shafts(blue)?
I think the 48mm drive shafts might be too long because the Ver.II comes with the short arms, so it would be better to go for the 46mm drive shafts.
51092 - 46mm Swing Shaft (front)
53742 - 46mm Swing Shaft - Lightweight (rear)
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 07-26-2009, 12:14 AM   #93
Super Moderator
Grizzbob's Avatar
Agreed, the v.2 manual specifies the 46mm dogbones(which I've already installed on mine), & they look like that's about as long as will fit in there right now. As for the car itself, I'm back from my first day testing it, & I have to say, I'm VERY pleased. There are a few things I'll want to add still, but considering I ran it today with the plastic diffs all around & no sway bars(I have some, but they're on another car which I forgot to bring), I was quite impressed with how it handled. Here's a few pics of it, including one I took to show how tight the space for the ESC is. Next thing I'll want to do is add a front one-way, the sway bars & some aluminum diff halves for the rear.....
TA-05 ver.2-ta05v.2_gtr.jpg.jpg   TA-05 ver.2-ta05v.2chassis1.jpg.jpg   TA-05 ver.2-ta05v.2esc.jpg.jpg
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 07-26-2009, 02:21 AM   #94
bl4
bl4's Avatar
Can we use 53724 for front & rear?
bl4 is offline   Reply With Quote
Old 07-26-2009, 03:26 AM   #95
Skitee's Avatar
Very nice it really looks good just a question on the ESC space, is the space smaller ? I thought it may have slightly more space because the new chassis doesn't have that strange cut in at the bottom right hand corner like the original chassis had.
Old 07-26-2009, 03:28 AM   #96
Skitee's Avatar
You can use them at the front but they are likely to bend in a crash.
Old 07-26-2009, 05:48 AM   #97
bl4
bl4's Avatar
OIC thks for all the info!
Old 07-26-2009, 08:43 AM   #98
Nice job ob the body too. I like the paint scheme.
rabosi is offline   Reply With Quote
Old 07-26-2009, 12:06 PM   #99
Super Moderator
Grizzbob's Avatar
Yes, the space IS tighter, I couldn't quite get the GTB to sit totally flush, though I think it's low enough & secure enough to be ok, but I can't see anything bigger fitting at all...
Bob Seay
Go Pokes!!!
Old 07-26-2009, 12:07 PM   #100
Super Moderator
Grizzbob's Avatar
I agree, they should work, but if you use a spool or one-way up front then I'd expect them to bend or break pretty easily...
Bob Seay
Go Pokes!!!
Old 07-26-2009, 01:04 PM   #101
Skitee's Avatar
Please can I ask you to measure the length and width of the ESC area in the chassis?
Old 07-26-2009, 06:41 PM   #102
Super Moderator
Grizzbob's Avatar
Well, it's not so easy to do with the ESC Shoe-Goo'ed down, but I gave it a try & it looks to be about 37mm by 47mm(but I'm not sure if that includes a ridge that's in there that separates the ESC area from the motor's area)...
Bob Seay
Go Pokes!!!
Old 07-26-2009, 09:58 PM   #103
kdeselms's Avatar
I just finished building my chassis (short of electronics, that has to wait till the first of the month)...photoblogged it on my site (see signature), if you're curious. My first time building an on-road kit. Tamiya does a great job, just wish they'd be as helpful as other manufacturers in bagging steps together, etc...
So Grizzbob, what pinion are you running with a 17.5 motor, on this? I'm new to both belt drive train and 4wd!
Kevin Deselms
Associated Factory Team SC10
Webmaster, www.hotrodhobbies.com
kdeselms is offline   Reply With Quote
Old 08-01-2009, 02:10 AM   #104
bl4
bl4's Avatar
The stock pinion 20T gear is for acceleration or isit better for high end? Pls adverise thks!
Old 08-01-2009, 04:51 AM   #105
Skitee's Avatar
The Tamiya pinions come in sizes from 16 to 25 teeth, so the 20 tooth pinion in the kit should give you a good balance of acceleration and top speed depending on the motor you're going to use.
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 10:20 PM
