Old 06-23-2010, 12:23 PM   #1021
fat500's Avatar
Trader Rating: 29 (100%+)
will the alum diff housings for the ta05 fit the v2? are the alum diff parts the same as well? other than chassis, motor mt, what else is specific to this chassis. I do not want to order the wrong hopups.thanks.
fat500 is offline   Reply With Quote
Old 06-23-2010, 12:44 PM   #1022
HarryN's Avatar
Send a message via AIM to HarryN
I really don't know what else is different visually between the v1 and v2.
Car(s): Team Losi 22 1/10 Buggy, Team Losi 22 1/10 Stadium Truck
Motors/Engines: SP 13.5 v1.0, SP 17.5 v3.0 x2, RevTech 7.5
Radio: Spektrum DX3R, DX3S
Cars For Sale: FG 08-530 EVO w/ Sport Brakes!
Track(s): http://www.rctrack.com
HarryN is offline   Reply With Quote
Old 06-23-2010, 01:40 PM   #1023
Skitee's Avatar
The V2 uses the same aluminum diff outdrives as all other TA-05 versions, the aluminum bulkheads are also the same if that is what you are reffering to as the diff housing.
Other differences are TB-03 steering arms, 2 piece suspension blocks for the Front Rear and Rear Front blocks, TB Evo IV B parts(Bumper)
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 06-23-2010, 02:25 PM   #1024
fat500's Avatar
Thanks one more... will the 49440 aluminum center plate work? does it replace the plastic spur gear covers? Thanks
Old 06-23-2010, 10:55 PM   #1025
Skitee's Avatar
No that won't work on the V2
Old 06-24-2010, 05:35 AM   #1026
HarryN's Avatar
My friend's car also uses separate mounts on the front and rear front blocks and the TB-03 steering arms. Unless he started using these parts recently.
Old 06-24-2010, 07:58 PM   #1027
Super Moderator
Grizzbob's Avatar
Yes, the ver.2 uses the new separated suspension mounts(the inner ones where the belts would pass under with the old mounts, the outer mounts are the standard ones), not really any performance advantage, but they are pretty cool & are easier to change out than the old ones. Plus, I don't know if anyone's said it yet, but the ver.2 also uses the same shortened suspension arms that the TB03 & the 416WE & 416X uses(though the ones one the ver.2 & TB03 are made of the more flexible plastic, but are otherwise identical, & btw, they seem to hold up VERY well, too, quite durable)....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 06-25-2010, 06:31 AM   #1028
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
For you guys running front spools in your IFS V2 are you running the Tamiya version or is another brand any better or longer lasting? I saw a pick of the Tamiya one but not a clean enough one to see if it uses plastic blades or not so it don't damage the alum. outdrive? I know with other cars straight drive pins gouge out the aluminum if you not using some sort of plastic blade.
Been running touring cars for years and wonder just how competitive this car can be against the high end so called luxury touring cars? I need to have the fastest car but at this time looking for a car that is a little smoother to drive overall than some of the other cars I have ran in the past. I did watch one last week at a bigger race against all the high end cars and it was easily holding its own and looked very smooth to drive overall.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 06-25-2010, 06:34 AM   #1029
HarryN's Avatar
Hey WYD, my TA-05 V2 spool doesn't need any blades. The CVD end fits in nice and snug. I put some Tamiya AW grease on it just in case. So far it is hold up very well.
As far as being competitive, I would say it has a HUGE potential. But you will have to upgrade a few things first. I know my car is showing tons of potential. As bad a driver as I am, I find the car extremely responsive and easy to control versus the T3 I had. It also has a very huge sweet spot, so setting the car up is almost a no brainer.
Old 06-25-2010, 03:31 PM   #1030
wyd
Tech Legend
wyd's Avatar
Cool. Thanks for the info. For me I just don't get to race enough anymore and just want something a little more forgiving overall that is closer to working at more tracks. I don't need to have the fastest but just a car that is overall easier to drive that I can buy parts for fairly easy.
If your getting it to work at Mimis and its not breaking it is a killer car. I never do well when I have been their in the past. I have not been on the asphalt yet but not much luck when I ran carpet rubber tire when I was their last.
Might be looking to get a 05 IFS v2 very soon.
Old 06-25-2010, 05:48 PM   #1031
fat500's Avatar
the outdrives on the tamiya spool are steel. no worries about wear the 3 racing spool also has steel ones.
Old 06-25-2010, 06:03 PM   #1032
Kyuss's Avatar
Daaaaaa Bearsssss
Kyuss is offline   Reply With Quote
Old 06-25-2010, 06:17 PM   #1033
fat500's Avatar
what are the advantages of running 1c/1c blocks in the front of the v2 as opposed to the kit setting of 1a/1a. i noticed the 416 uses 1c up front but uses the same short R suspension.
is the chassis geometry that different that tamiya would spec the v2 with the a blocks up front? the back of the manual does not even show the c blocks as an option for tuning the front of the car. Thanks.
And thanks to Core Creations for the killer deal on the V2 kit.
Full hop-ups are on the way.
I have a tb03r I have been racing in stock spec rcgt using the cirtix system and am looking for a change.
I will be building the v2 up to full R specs over the next week to match the tb03r and will post pics in addition to a comparson of the 2 chassis different driving characteristics.
I am very interested to see what chassis will be better suited to my driving style
Old 06-26-2010, 07:22 PM   #1034
fat500's Avatar
anyone everyone racing
Old 06-26-2010, 09:30 PM   #1035
sonic31's Avatar
the advantage is... nothing, absolutely nothing hahahahaha i still kick your ass with my 416x
Tamiya TRF418 SAMIX / KO Propo / Tekin RS Pro / Spektrum
sonic31 is offline   Reply With Quote
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 10:20 PM
