Old 06-08-2010, 05:04 AM   #1006
HarryN's Avatar
Send a message via AIM to HarryN
Originally Posted by Grizzbob View Post
Personally, I prefer the molded parts, as you need to have some part of the car that has some "give" to it, helps protect the more vital(read more expensive) parts when you hit something, & about your last question, yes, ALL suspension parts from the 416 will fit, as well as suspension parts from the TB03(they all share the short arm suspension & front bumper/body mount parts)....
Thank you sir! So I guess the CVDs should fit just fine then, if the suspension parts fit just fine. I am getting tired of the dogbones popping out when I hit something coming around a corner. And it only happens on the right side too! Maybe I should use another one of those sponge thingies in the slots to push the dogbone in more?
Car(s): Team Losi 22 1/10 Buggy, Team Losi 22 1/10 Stadium Truck
Motors/Engines: SP 13.5 v1.0, SP 17.5 v3.0 x2, RevTech 7.5
Radio: Spektrum DX3R, DX3S
Cars For Sale: FG 08-530 EVO w/ Sport Brakes!
Track(s): http://www.rctrack.com
HarryN is offline   Reply With Quote
Old 06-08-2010, 11:02 AM   #1007
HeliYogi's Avatar
Trader Rating: 16 (100%+)
Default Cheap: Diff & Dog bones
Same thing happens to me, I put more sponge to try hold the right dog bone, no good. Also the diff becomes lose easily after a soft or medium bump and it losses all front pull. When it starts tail out spinning in the turns, or turning hard right as I brake, it's a sing that front the diff went louse.
I was not gladly surprise to see how cheap the stock diff/drive train is for the TA05 V2.
So I spent another $40 for a direct spoll and a 46mm universal set.
Should I be using the kit stock 37 pulley with the spoll or the one that comes with it?
Thanks guys, Marcos
TA-05 ver.2-image_059.jpg   TA-05 ver.2-image_063.jpg   TA-05 ver.2-image_062.jpg   TA-05 ver.2-image_058.jpg
More F-1 RC action? RCTECH Formula-1-RC-Northwest & FB @WhatBrakes
HeliYogi is offline   Reply With Quote
Old 06-08-2010, 08:09 PM   #1008
Super Moderator
Grizzbob's Avatar
Thanks guys, Marcos
You'll need the pulley that's meant for one-ways & spools(you'd have to do some mods to the stock pulleys, & it's not worth the mess, the dedicated pulley already is drilled for the mounting screws & has a bigger center hole to sit properly on a one-way or spool). Oh, & also about universals, which ones you can use will depend a bit on how you set the suspension up, if you use similar suspension mounts as the 416(usually either 1C/1C front & 1XA/1F rear, like the 416WE) then 44mm universals will work, but 46mm ones are still preferred(they will fit most any suspension mount combo that racers are currently using with no chance of popping out of the outdrives). I'd also reccomend using the steel ones up front(especially if you use a one-way or spool) but you can use aluminum one in the rear without problem(the aluminum ones can get torn up more quickly up front but in the rear with a diff they hold up just fine).....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 06-10-2010, 05:24 AM   #1009
HarryN's Avatar
Hey All, I have a new question and experienced this last time I raced the car. I noticed that on the straights when I really punch the throttle, my car tracks left, but when on in the infield, it tracks straight. One of my fellow racers that owns the car says it is the diff. And sure enough, when I checked the diff, it got TIGHTER?? Is this normal? What is causing it? Any word of advice?
Thanks!
Old 06-11-2010, 08:21 PM   #1010
bl4
bl4's Avatar
Does anyone know the Tamiya part no. for the carbon reinforced reversible arm?
bl4 is offline   Reply With Quote
Old 06-12-2010, 12:52 PM   #1011
BigRon's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to BigRon
Default Chassis suspension mount direction
Guys, when using the separate suspension mounts. Is there a perfered way to mount them? I mean to use "1XB" setting should they be mount like "1XB/1B - 1B/1XB" or "1B/1XB - 1XB/1B". For some reason I'm having a brainfart on this. LOL
*Serpent America*
SRX-2 ~ F110 SF2 ~ S100 LTR ~ 4X
Desoto Racing ~ KO Propo
BigRon is offline   Reply With Quote
Old 06-12-2010, 01:44 PM   #1012
You take the setting from the letters toward the inside.
So if you mount the blocks with 1XB toward the center, that is the equivalent of the old single 1XB block. Which, I think, would be written 1B/1XB - 1XB/1B.
Hope that helps.
BNiels707 is offline   Reply With Quote
Old 06-12-2010, 02:09 PM   #1013
BigRon's Avatar
*Serpent America*
Old 06-12-2010, 11:50 PM   #1014
HeliYogi's Avatar
You'll need the pulley that's meant for one-ways & spoolst torn up more quickly up front but in the rear with a diff they hold up just fine).....
Thank you Grizzbob! Will do the changes and post the results
Cheers,
Marcos
Old 06-13-2010, 05:12 PM   #1015
HarryN's Avatar
I think it is TAM53928?? Not sure, I just bought the entire set of them. The part number is TAM54083. It is a very good deal in my opinion.
Also, I have a question about the direct coupler. I swapped the 37T gear from my one-way that came with the v2 kit (and upgrade pack) and it seems like the front belt is extremely loose. No matter where I put the setting on the bearing housing to tighten the belt, it was very very loose. Did I do something wrong? Am I using the wrong gear?
Old 06-13-2010, 06:12 PM   #1016
bl4
bl4's Avatar
Thks!
Old 06-21-2010, 06:34 PM   #1017
fat500's Avatar
Trader Rating: 29 (100%+)
looking for a v2. I have a lrp spx and 17.5 x12 to trade with some cash or a all cash paypal deal. looking for someone with good feedback here . pm me what you have. thanks.
fat500 is offline   Reply With Quote
Old 06-21-2010, 08:32 PM   #1018
Core Creations's Avatar
Trader Rating: 93 (100%+)
Send a message via AIM to Core Creations
Ygpm!
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 06-23-2010, 06:57 AM   #1019
hi guys
I am currently running TA05. Can anyone tell me what is the added advantage of the TA05V2 ? Also what is the difference parts between the TA05 and TA05V2. Can i convert my TA05 into a version 2?
ronaldo-1234 is offline   Reply With Quote
Old 06-23-2010, 07:17 AM   #1020
HarryN's Avatar
Originally Posted by ronaldo-1234 View Post
hi guys
What I have noticed in comparison of my v2 versus my friend's v1 is that my chassis is narrower, is more LiPo friendly, I have 37T diff gears front and rear with 18t in the center, the center motor mount is different, I have longer belts front and rear. Other than that, nothing else was different.
As far as the advantage, your car can roll more and not have the sides of the chassis rub on the floor. I don't know really.
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 10:20 PM
