Old 06-01-2010, 07:16 PM   #976
Hi guys,
Can anyone be so kind enough to tell me if the TRF415 aluminum outdrives of its ball diff fit the TA05 ver 2? Please let me know. Thanks.
speedykupad is offline   Reply With Quote
Old 06-01-2010, 09:15 PM   #977
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
Originally Posted by speedykupad View Post
Hi guys,
i think they're different. there's a specific alum diff outdrive set for the TA05 series (TA05, IFS, Ver2)
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 06-02-2010, 01:27 AM   #978
Thanks sir.
Old 06-02-2010, 04:11 AM   #979
slakr's Avatar
Trader Rating: 28 (100%+)
53919 Tamiya TA05 Aluminum Differential Joint Set (w/blades)
OR
49425 TA05 Aluminum Diff Joint (Blue)
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 06-02-2010, 07:57 AM   #980
HarryN's Avatar
Send a message via AIM to HarryN
Actually, speedykupad just inspired a question in my mind. I was wondering, what parts are interchangeable between the TA-05 IFS, V2, etc. and the 415 and 416??
Car(s): Team Losi 22 1/10 Buggy, Team Losi 22 1/10 Stadium Truck
Motors/Engines: SP 13.5 v1.0, SP 17.5 v3.0 x2, RevTech 7.5
Radio: Spektrum DX3R, DX3S
Cars For Sale: FG 08-530 EVO w/ Sport Brakes!
Track(s): http://www.rctrack.com
HarryN is offline   Reply With Quote
Old 06-03-2010, 11:16 AM   #981
cheehtae's Avatar
Trader Rating: 15 (100%+)
susp. arms, blocks, hubs, pulleys. This is for the short suspension arm.
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 06-03-2010, 01:06 PM   #982
HarryN's Avatar
This is awesome. How about the CVDs? Would the 46mm or 44mm swing shafts work in the TA-05? I am trying to get whatever my LHS has in stock so I don't wait an Aeon for parts to be in stock.
Old 06-03-2010, 01:10 PM   #983
Hebiki's Avatar
Trader Rating: 26 (100%+)
yes you can use the swing shafts. you just need to make sure you have the correct axles. the lightweight suspension ORIGINALLY came with 5x9s. the 416 version of the same suspension uses 5x10 bearings, so the length of the axle changed.
for the TA05V2.. you'll need 46mm swing shafts using the "stock/instruction manual" suspension block set up.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 06-03-2010, 01:50 PM   #984
HarryN's Avatar
Well if that is the case, could I not just change the size of the bearings to allow the axles to fit? Or is there something more I am missing?
What do you mean by stock/instruction manual suspension block set up?
Old 06-03-2010, 02:14 PM   #985
Hebiki's Avatar
nope.. you would have to change the steering knuckle as well.
read your manual... they probably suggest that the front uses A/A and the rear uses XA/D or XA/E for suspension blocks.
if you use narrower blocks.. you'll need shorter swing shafts.
Hebiki Design Works
Old 06-03-2010, 07:10 PM   #986
C&B RC's Avatar
Default Price????
Whoa what happened
I been saving for a v2 with the upgrade package and the price jumped $100 in the last 2 weeks and everybody's out.
It's all fun & games til the flying monkeys show up!
C&B RC is offline   Reply With Quote
Old 06-03-2010, 07:17 PM   #987
mc4798's Avatar
Originally Posted by C&B RC View Post
Whoa what happened
Got mine ordered from here.
http://www.rcmart.com/catalog/rc-tam...s-p-30707.html
Waiting on that free ems shipping deal they had
ckhobby.com
USA Distributor of Dualsky Advanced Electronics
mc4798 is offline   Reply With Quote
Old 06-04-2010, 05:38 AM   #988
HarryN's Avatar
Well everyone, I got the car built and the 5 degrees it recommends in the steering servo setup is way off. I extended the steering linkage to 16mm and I still could not get to the 5 degree setup the manual said to setup. I later changed the direction of the servo to 15 degrees and it is straight again.
Am I doing something wrong or do some servos require more degrees when setting up the stationary point of the servo saver?
Other than that, the car drove extremely well on its first drive out!! I hadn't even done any setup changed or even changed the springs!!
Old 06-04-2010, 07:27 AM   #989
RC MARKET's Avatar
Ver.2 Carbon chassis
RC MARKET is offline   Reply With Quote
Old 06-04-2010, 09:00 AM   #990
KREATOR1's Avatar
Send a message via Yahoo to KREATOR1
what is the different between the old one?
TA04ss / TA04TRF / TB EvoIII/ TB02 /DF02 / M03L / TRF414m2 / TRF415 / TRF415MS / TRF415MSX / MRE
KREATOR1 is offline   Reply With Quote
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 10:20 PM
