Old 05-26-2010, 03:17 PM   #961
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by HarryN View Post
Well I am not going to make it a blue monster. Just the ones people are recommending to get, that do not come with the kit already like the suspension mounts, and the CVDs for the car. Other than that, what else is really needed? Sway bars?
I mean I can always add the bling in later. Just wanna get the car nice and sturdy first.
sway bars.. yup. i like having alum. rocker arms on there as well....and the hop up shocktower for the rear.
the alum. bulkheads are a great hopup but costly..... BUT their cost is worth the trouble because it helps when changing roll centers and camber link lengths. the plastic pieces wear out quickly. same with the carbon reinforced ones as well.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 05-26-2010, 06:03 PM   #962
HarryN's Avatar
Send a message via AIM to HarryN
Well I tell you what, lemme list the parts I gave to my LHS and you tell me which one you feel I should get or pass on. This is from the TamiyaUSA website:
TAM53846
TAM53847
TAM53877
TAM53876
TAM53875
TAM53844
TAM53842
TAM53811
TAM53810
TAM53809
TAM53808
TAM53896
TAM53990
TAM53952
TAM53919
TAM53905
TAM54197
TAM54196
TAM54175
TAM54174
TAM54173
TAM54172
TAM54171
TAM54095
TAM54089
TAM54083
TAM54073
TAM54072
TAM54071
TAM54070
TAM54069
TAM54019
Are those the parts you recommend I get?
I was hoping Speedtechrc.com would have them in stock, but they are out of them, sadly.
Car(s): Team Losi 22 1/10 Buggy, Team Losi 22 1/10 Stadium Truck
Motors/Engines: SP 13.5 v1.0, SP 17.5 v3.0 x2, RevTech 7.5
Radio: Spektrum DX3R, DX3S
Cars For Sale: FG 08-530 EVO w/ Sport Brakes!
Track(s): http://www.rctrack.com
HarryN is offline   Reply With Quote
Old 05-26-2010, 09:01 PM   #963
I got a problem. When i turn left the car likes to spin out. When i turn right it understeers.
I added extra spring spacers on the rear left side and that fixed the problem now the car sits higher on the left side.
Does anyone know what the problem is? I added sway bar kit also.
tpsolid is offline   Reply With Quote
Old 05-26-2010, 09:16 PM   #964
Hebiki's Avatar
TAM53846
TAM53847
TAM53877
TAM53876
TAM53875
TAM53844
TAM53842
TAM53811
TAM53810
TAM53809
TAM53808
TAM53896
TAM53990
TAM53952
TAM53919
TAM53905
TAM54197
TAM54196
TAM54175
TAM54174
TAM54173
TAM54172
TAM54171
TAM54095
TAM54089
TAM54083
TAM54073
TAM54072
TAM54071
TAM54070
TAM54069
TAM54019
wow thats a long list. you mind editing it and adding some descriptions?
Hebiki Design Works
Old 05-26-2010, 09:46 PM   #965
fullout's Avatar
Send a message via MSN to fullout
It could be a balance issue side to side. If you are running a lipo, chances are you will need to add weight to the battery side of the car to make it balance correctly. i had to add atleast 70 grams to make mine work.
fullout is offline   Reply With Quote
Old 05-26-2010, 10:39 PM   #966
if its too heavy on the electronics it will over steer when turning left?
Old 05-26-2010, 10:56 PM   #967
Skitee's Avatar
You should also check a few other things...
Tub might have a permanent tweak in it.
Steering links must be the same length left and right.
All 4 shocks need to be the same length.
All 4 shocks need to be mounted at the same position.
Radio EPA should be equal left and right.
Radio Exponential should be equal left and right.
Check that you have the same amount of left andd right travel on the servo.
Uneven droop / down stops could also cause this.
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 05-26-2010, 11:01 PM   #968
fullout's Avatar
My bad, i read it wrong. My car was doing the opposite and weight is what fixed it.
Old 05-27-2010, 09:08 AM   #969
I built my shocks per instructions. There is about 3mm of space between the spring and spacer when the spring is fully uncompressed. Is that correct build?
I will check the rest when I get home.
Old 05-27-2010, 09:13 AM   #970
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 05-27-2010, 09:37 AM   #971
HarryN's Avatar
It is a long list, but here is what is included with the part numbers (took me a good hour to make that list):
Rear carbon shock tower
1x seperate suspension mount
1xA/B/C/D/E & 1A/B/C/D/E - Seperate suspension mounts
Tamiya Spring Set
Tamiya CVDs (46mm)
Tamiya Suspension Holder A/B/C/D/E
Aluminum Bulk Heads (F and R)
Aluminum Motor Mount
Aluminium Top Plate for Motor Mount
Aluminum center one-way Pulley
Front Direct Pulley
Front One-Way Pulley
Aluminum Steering Set
Carbon Battery Plate
Aluminum Roll Center Plates (.5mm and 1mm)
Aluminum Differental Shaft
Aluminum Transponder Stay
Aluminum Servo Mounts
Carbon Steering Link
High Precision Diff Joint
Aluminum Side Brace
51297- Reversible Arm Suspension Kit (Short)
53882- Carbon Mount Spacer Stay (I am assuming for the front)
Tamiya F Parts
Tamiya C Parts
Aluminum Battery Post
Stabilizer Set
I believe that is the list. I don't know why Tamiya just doesn't release a TA05 v2 TRF kit.
I will be upgrading slowly as things break, since I can't afford everything at the same time. I will probably start off with the aluminum suspension holders and rear carbon shock tower then start working up from there to ultimate bling.
Old 05-27-2010, 10:29 AM   #972
I did some searching on google and came up with i topic. The guy was having the same problem. He found out his diff was slipping? I did not apply any glue to my rear diff to lock the plate to the outdrives.
U guys think its slipping?
I'll try that when I get home.
Old 05-27-2010, 10:38 AM   #973
superspeed's Avatar
is the TCS series running brushless motor in their classes now? I know they were running li-po for the f103gt class.
superspeed is offline   Reply With Quote
Old 05-27-2010, 11:40 AM   #974
240Z's Avatar
TA-05 is a TCS eligible chassis for GT3 and GT2.
GT3 is currently 540J brushed motors only.
GT2 is 17.5 BL. Any speed controller can be used, but expect that to change in 2011.
LiPo's have been allowed for years in TCS racing.
240Z is offline   Reply With Quote
Old 05-27-2010, 01:58 PM   #975
superspeed's Avatar
cool, I have been racing TCS since 2006 north american final, it's good to hear that BL and lipo are allowed. looks like got to get back into the racing scene.
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 10:20 PM
