Old 05-13-2010, 09:44 AM   #931
Originally Posted by snewman View Post
Thanks for the response gimpex.
Regarding the rules for the class - we can use any IFMAR legal chassis with any hop-ups provided that "Kits and hot-ups must be assembled as per manufacturers instructions", so I'm okay if I need to replace the spur cover.
Update: just got the kit in the mail today!
So I've measured the 70 tooth spur (48P) included in the kit and its 43mm in diameter - how does that compare to the diameter of the 105T 64P spur?
I'm hoping that the finer pitch combined with the lower number of teeth on the 95T spur will fit.
If anyone has a 95T spur could they post the diameter of the gear?
Hmm, I dont know , to me it sounds like it must be as per original kit - meaning no changes - best you find out what they mean exactly
By the way the 70T spur is not 48P...it is of the .6 variety.... with larger spurs - 95T , 105T - being .4 kind ( some say that you can use the metric with imperial pitch but I havent tried it)
gimpex is offline   Reply With Quote
Old 05-13-2010, 11:22 AM   #932
@snewman
Been running 48T motor that requires a low final drive ratio setup and i can safely say, yes you can fit in a 95T pinion.
Currently, i'm using a 64pitch 43T pinion and 90T spur.
jarrydtan is offline   Reply With Quote
Old 05-13-2010, 04:37 PM   #933
I read over the detailed rules and they're okay with hop-ups as long as they're standard off the shelf items made for that chassis.
Good point on the gear pitch - I forgot that the Tamiya's use the metric pitch. I'm looking to change over to 64P anyway as there's a broader range of spur and pinions available.
snewman is offline   Reply With Quote
Old 05-13-2010, 04:45 PM   #934
Originally Posted by jarrydtan View Post
@snewman
Thanks for that - I'll go ahead and order the spur and pinion.
Old 05-13-2010, 04:49 PM   #935
I have a second question:
What have you guys been using to glue the diff plates to the outdrives?
The manual talks about "synthetic rubber cement" while I've also seen others using CA (eg the build project at side-fx - sorry can't post URLs yet).
I ended up using Tarzan's Grip very sparingly, cleaned up any excess and polished the diff plate. Worked great.
Old 05-14-2010, 08:27 AM   #936
bl4
bl4's Avatar
Hi any bro tried using 18T Centre pulley and Wide pitch differential pulley(36T size) Spure 70T, pinion 22T? What is the different if use back the stock 37T differential pulley? Kindely adverise on this setting thks.
bl4 is offline   Reply With Quote
Old 05-14-2010, 10:27 AM   #937
Hebiki's Avatar
Trader Rating: 26 (100%+)
very minimal would be the difference. your internal ratio would go from 2.05 (with the 37T pulley) to 2.00 (36T wide pitch pulley)
not sure if you would notice a "performance" difference.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 05-17-2010, 01:43 AM   #938
spazmo's Avatar
Noob question time?
The setup sheet has damper retainer normal or 1mm down.
Can someone please explain what this is?
Cheers
spazmo is offline   Reply With Quote
Old 05-17-2010, 03:58 AM   #939
mc4798's Avatar
Default Spur Gears
Any issue with using Robinson Racing 64p spur gears ?
If so what you guys recommend
mc4798 is offline   Reply With Quote
Old 05-17-2010, 09:52 AM   #940
Hebiki's Avatar
Originally Posted by spazmo View Post
Noob question time?
Cheers
the stock (plastic) spring retainer (depending on other factors within your car like shock length, stock shock tower or hopup, etc) sometimes prevents you from making ride height.... so Tamiya released the hop-up spring retainer that lets your spring sit 1mm lower so you can make ride height.
so if you find you've loosened your shock collars all the way to the top, and still cant lower your ride height, try the 1mm spring retainers to help.
Hebiki Design Works
Old 05-18-2010, 09:02 PM   #941
HeliYogi's Avatar
Trader Rating: 16 (100%+)
Default Spoll problem
Appreciate all your help guys.
Problem:
Try to install Tamiya spoll, had to bail out of GT3 last weekend at TCS
This is what happened:
When my wheels are pointing either left or right - throttle anywhere from 20% to 100%, there is a significant amount of vibration, it sounds even worse "KRAK KRAK" but not a full lock.
If the car is on the track it's like the front dog-bones are out of place. the front of the car jumps up and down.
The problem is not there so when the wheels are pointing straight. The problem is also not there with stock front differential installed.
Any thoughts?
Thanks!
Marcos
More F-1 RC action? RCTECH Formula-1-RC-Northwest & FB @WhatBrakes
HeliYogi is offline   Reply With Quote
Old 05-18-2010, 10:15 PM   #942
Hebiki's Avatar
Problem:
Any thoughts?
Thanks!
Marcos
the chatter from the spool is probably causing havok with the dog bones. if you can upgrade to universals, your problem might be solved....
thats just my guess. you could have come up to me. i was running a TB-03 in GT3 at TCS last weekend.
Hebiki Design Works
Old 05-18-2010, 10:33 PM   #943
HeliYogi's Avatar
It will sound ingnorant but what are universals? If i knew who you are I would have called for help, but who are you?
Thanks!
Marcos
Old 05-18-2010, 10:56 PM   #944
Hebiki's Avatar
Thanks!
Marcos
i was the one pitted in the corner by the offroad track.
universals are these...
this:
http://www.speedtechrc.com/store/ebp...id=462&id=1687
plus this:
http://www.speedtechrc.com/store/ebp...id=462&id=1716
and these:
http://www.speedtechrc.com/store/ebp...id=615&id=7704
Hebiki Design Works
Old 05-18-2010, 10:57 PM   #945
Hebiki's Avatar
Thanks!
Marcos
oh.. one more thing.. you use steel swing shafts (pictured above in 44mm) and alum in the rear for the TB-03.
46mm for TA05V2.. but varies depending on your suspension blocks
Hebiki Design Works
Electric Touring / On-Road RC Screaming Wind Manila Racers 32165 10-24-2016 09:33 PM
