Old 04-16-2010, 04:03 AM   #886
Trader Rating: 114 (100%+)
When you glue the diff rings, only glue the outer edge, that is all you need. To replace them in the future the glue easily scrapes off. Another option instead is to use heavy diff grease to keep the plates from moving. Like 15k Kyosho diff grease.
Chris Furman is offline   Reply With Quote
Old 04-16-2010, 09:19 AM   #887
Skitee's Avatar
You can also use Tamiya anti-wear grease or Hard friction damper grease behind the diff plates.
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 04-17-2010, 06:47 PM   #888
Got a question for one of you Tamiya experts.
What is the difference between the Flourine Shocks and the Hard Black Coating shocks?
If you had a choice which would you go with?
Any info would help.
Freezer7676 is offline   Reply With Quote
Old 04-17-2010, 11:46 PM   #889
Hebiki's Avatar
Trader Rating: 26 (100%+)
+1
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 04-17-2010, 11:46 PM   #890
Hebiki's Avatar
hard black coating i believe is the "newest" version of the TRF shocks. very smooth. this is what i have on my cars.
Hebiki Design Works
Old 04-18-2010, 07:31 AM   #891
+1...
but they are ALL good.
Old 04-18-2010, 07:32 AM   #892
I sure hope they release 54231 carbon chassis for this car soon.
Old 04-18-2010, 07:34 AM   #893
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
+1
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 04-30-2010, 06:03 AM   #894
what are the best upgrades for the v2? alum bulkheads?
tpsolid is offline   Reply With Quote
Old 04-30-2010, 10:07 AM   #895
Mr LowDown's Avatar
Trader Rating: 21 (100%+)
can i use the alum bulkhead ( front and rear ) from my TA05IFS?
( planning to get V2 soon,but got loads off TA05ifs part )
Mr LowDown is offline   Reply With Quote
Old 04-30-2010, 10:08 AM   #896
hacker's Avatar
Trader Rating: 140 (100%+)
+1
how are the shocks compared to trf's?
I know first thing I will be getting is the front cvd's
hacker is offline   Reply With Quote
Old 04-30-2010, 10:47 AM   #897
Hebiki's Avatar
yes you can use them. good upgrade if you make lots of changes to roll center... the holes for the camber links wears out on the carbon/plastic pieces.
Hebiki Design Works
Old 05-01-2010, 04:57 PM   #898
Hey guys I could use some help. I'm assembling my TA05Ver2 and I'm trying to install the rear dogbones. I've got a problem with the left ( drivers) side. The diff is too shallow and the bone won't fit deep enough in to it. I've double checked the assemble of the diff, it's installed in the car with the nut side facing the left. The turnbuckles are the correct lenght, the ball studs are in the correct holes on bulkhead and the axle holder. The right side seems too deep and the bone falls out. Any suggestions? Thanks
outlandr91 is offline   Reply With Quote
Old 05-01-2010, 07:08 PM   #899
Hebiki's Avatar
insert the pink foam on both sides.
Hebiki Design Works
Old 05-01-2010, 07:20 PM   #900
On the right side, I've got the black o ring in the axle and the pink spacer(uncut) in the diff. I can slide the bone into the diff enough that the bone falls out.
On the left side, I've got the o ring in the axle and a 1/2 pink spacer in the diff. Like I said, the bone won't go deep enough into the diif, I can't get the turnbuckle installed.
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 10:20 PM
