Old 04-05-2010, 01:56 PM   #871
Originally Posted by Akudou View Post
Anyone knows which other tamiya's knuckle and c-hubs which will fit the verII. I lost my oirginal king pin today on the track and along with 2 other yeah racing kingpin set. Tried 3 racing knuckle before and it broke even on drifts.
the c-hub should be part #54031
and the knuckle should be part #51332
platypus_s13 is offline   Reply With Quote
Old 04-05-2010, 04:44 PM   #872
Chris Furman's Avatar
Trader Rating: 112 (100%+)
sorry.. you have the wrong numbers:
C-Hub 4 degree - 51293..
Here is a site with all of the correct part numbers: http://www.speedtechrc.com/store/ebcategory.asp?id=859
Chris Furman is offline   Reply With Quote
Old 04-05-2010, 04:45 PM   #873
Originally Posted by Goingfast View Post
Who got the carpet set up for TA05?
TA05 what? R? IFS? V2?
Ozite carpet? glued? or not glued?
Size of track? what motor? and tires are you using?
is it loose or pushing?
we need some more specifics for your request.
Old 04-05-2010, 05:13 PM   #874
thanks for the correction!
Old 04-05-2010, 05:37 PM   #875
CSeils's Avatar
Trader Rating: 48 (100%+)
That's for the kit C-hub. You can use 54031, that is what I replaced mine with when the kit ones broke.
You can never go wrong with a Hooters Mini. But Mini Hooters are bad.
--- USVTA National Points Series Member #122 ---
customracingstickers@gmail.com - http://www.rctech.net/forum/painting-designs-graphics-photography/279695-usvta-trans-am-decals.html
CSeils is offline   Reply With Quote
Old 04-05-2010, 05:51 PM   #876
Those are the graphite ones and quite a bit more fragile than the kit ones. If you guys are breaking the kit ones I would stick with the kit ones.
Old 04-05-2010, 06:22 PM   #877
Goingfast's Avatar
Trader Rating: 29 (100%+)
My have the TA05R and the carpet is the OZITE ,not glued and track 60X80
17.5 motor .what tamiya tires should have?
I'm rebuilding the car...
Everybody is ignorant, only on different subjects.
AE 12R5.1,Tekin RS PRO
17.5 super stock T.O.P PHOTON , TAMIYA M05 Mini
CEFX.. High Velocity Racing Motor
Goingfast is offline   Reply With Quote
Old 04-06-2010, 09:39 AM   #878
Tsquare's Avatar
Originally Posted by Skitee View Post
This is what you'll need to do a conversion from an IFS-R to a Ver.II
1 x 54095 - TB-03 Racing Steering Set
2 x 53851 - Titanium Coated 46mm Suspension Shaft
1 x 51253 - TB Evolution 5 "B" Parts
1 x 10115525 - TA-05 Ver.II "K" Parts
1 x 10115527 - TA-05 Ver.II "M" Parts
1 x 19115256 - TA-05 Ver.II Chassis
1 x 15405048 - TA-05 Ver.II Motor Mount
1 x 13454456 - TA-05 Ver.II Center Shaft
1 x 13454445 - TA-05 Ver.II Spur Gear Holder
1 x 54174 - TA-05 Ver.II SeperateSuspension Mounts (1C/1XC)
1 x 54172 - TA-05 Ver.II SeperateSuspension Mounts (1A/1XA)
If you want to complete the Ver.II conversion fully from a standard IFS then you'll need these parts too. It may actually be more cost effective to buy the Ver.II kit.
1 x 51092 - 46mm Swing Shaft
1 x 53742 - 46mm Swing Shaft - Lightweight
2 x 54076 - TB-03 Wheel Axles
2 x 53988 - TRF501X Ball Differential Pulley
2 x 51287 - Large Ball Diff Plate
1 x 53989 - TRF501X Center Pulley
2 x 54170 - TA-05 Ver.II Low Friction Drive Blet
2 x 53928 - Short Reversible Suspension Arm
1 x 54031 - TA05-IFS Carbon Reinforced F Parts - H Carrier (4deg)
1 x 51332 - TRF416 Front Upright
1 x 51333 - TRF416 Rear Upright
8 x 1050 bearings
Be sure to add Tamiya 840 Flanged bearings (Part 42110) these are used on the new motor mount.
Tsquare is offline   Reply With Quote
Old 04-11-2010, 12:56 AM   #879
i just got my tamiya ta05 ver 2 kit and am planning to get hop ups right away can someone give me feedback on quality and fit of 3 racing aluminum hop ups?
snake.doc is offline   Reply With Quote
Old 04-11-2010, 06:09 PM   #880
CRAP!
Wish I could get my money back for the few parts I tried from them. Buying Tamiya parts is expensive but in the long run it's cheaper than buying 3 racing parts and then replacing them with Tamiya parts.
Having said that, would you like to buy some of my 3 racing parts?
woodys3b is offline   Reply With Quote
Old 04-12-2010, 09:18 AM   #881
Tsquare's Avatar
Also add 54145 Foam Bumper.
Old 04-12-2010, 03:18 PM   #882
Tamiya parts are the ONLY way to go.
Old 04-12-2010, 11:45 PM   #883
thanks for the replies guess i'll be sticking with tamiya parts and fork out a lil more dough
Old 04-13-2010, 12:04 AM   #884
well just stay away from the plastics (3Racing). THe rest are pretty good! No probs so far ~
cheapskate.brok is offline   Reply With Quote
Old 04-16-2010, 02:29 AM   #885
spazmo's Avatar
Default Assembling diff
Just about to start assembling my kit.
The manual says to glue the diff plates to the out drives.
This is good in that it will stop the diff plate from moving against the outdrive and giving some slip or wear on outdrive.
But then it would not be possible to remove and reface the diff plate when rebuilding the diff in the future.
Any suggestions on this? does anyone run without the glue? any problems?
Do the metal outrives from the 416 fit? as these do not need to be glued
Next time I rebuild the diff I might replace with these
Cheers
spazmo is offline   Reply With Quote
Electric Touring / On-Road RC Screaming Wind Manila Racers 32165 10-24-2016 10:33 PM
SEO by vBSEO 3.5.0
