Old 03-25-2010, 06:56 PM   #856
Super Moderator
Grizzbob's Avatar
Originally Posted by CSeils View Post
Part # 51107. I'll see what i can find.
Okay, what about part # 54031 for the IFS, is it the same part? I know they both are 4 hubs.
Which one would you use?
Judging by the part description on Tamiya's site, I believe those are the carbon-filled ones, which tend to be kinda brittle. I'd stick with the softer ones, like KevinK said, or if you're in dire need, try the older style ones like I mentioned before(which is what I'm using on both my v.2 & my 416)....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 04-01-2010, 09:13 AM   #857
hi,
need advice from pros.. or TA-05 veteran
I'm planning to get a new chassis for touring purpose.. Was thinking about TA-05 version II and TRF416X. I'm just a casual racer who is not into competitive races. Will TA-05 sufficient for my purpose?
Earlier on posted the similar question in TRF416X thread.
Had a TT01 converted into drift that I want it remain to be a drift machine..
thanks a lot
hansenhon is offline   Reply With Quote
Old 04-01-2010, 09:21 AM   #858
stitchy's Avatar
Yes, TA-05v2 would be great for your purpose, especially the one with the upgrade pack
http://www.speedtechrc.com/store/ebp...id=120&id=9166
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 04-02-2010, 07:25 PM   #859
Trader Rating: 114 (100%+)
Originally Posted by hansenhon View Post
hi,
thanks a lot
TA05v2 with Upgrade Pack
Chris Furman is offline   Reply With Quote
Old 04-02-2010, 09:00 PM   #860
Tsquare's Avatar
Question - I have a TA05 IFSR and am converting to v2 - For those who have been running the v2 - what are the pros / cons vs TA05 v1? I am assuming it is better, but really haven't heard any specifics.
Tsquare is offline   Reply With Quote
Old 04-03-2010, 05:37 PM   #861
The V2 transitions from left to right a bit quicker since it has a narrower chassis. A little easier to work on due to the split block configuration. But you cannot go wrong with either car... both are fantastic.
Old 04-03-2010, 07:00 PM   #862
BigRon's Avatar
Trader Rating: 15 (100%+)
Send a message via AIM to BigRon
Are you guys running the plastice outdrives or have you upgraded to the aluminum ones? Also those pink urethane bushings have been backordered for a while. Is there a alternative out there?
BigRon is offline   Reply With Quote
Old 04-03-2010, 09:56 PM   #863
Tsquare's Avatar
Thanks Chris - Sounds good to me - I am also hoping the v2 chassis has less tweak than the TA05 v1.
Old 04-03-2010, 09:57 PM   #864
Tsquare's Avatar
I upgraded to the aluminum - I find them smoother and more durable. Do not know anything about the bushings though - Good luck with that.
Old 04-04-2010, 03:46 AM   #865
Tweak.. on a plastic chassis? haha... the V2 actually bends more than the V1 because it is plastic... V1 is available in Carbon which is much stiffer. V2 Carbon chassis is not shipping yet.
Old 04-04-2010, 01:47 PM   #866
Akudou's Avatar
Anyone knows which other tamiya's knuckle and c-hubs which will fit the verII. I lost my oirginal king pin today on the track and along with 2 other yeah racing kingpin set. Tried 3 racing knuckle before and it broke even on drifts.
Akudou is offline   Reply With Quote
Old 04-04-2010, 02:00 PM   #867
BigRon's Avatar
How are you guys correcting the tweek on these cars? Is it necessary to have a tweek gauge or is just easier?
Old 04-04-2010, 03:55 PM   #868
I almost don't even bother.. It changes from as soon as you move the car and the plastic flexes. Set your ride height, your droop and just drive it.
Old 04-04-2010, 04:35 PM   #869
Goingfast's Avatar
Trader Rating: 29 (100%+)
where did everybody get their set up for TA05 indoor carpet race??
Can somone post their set up?
Everybody is ignorant, only on different subjects.
AE 12R5.1,Tekin RS PRO
17.5 super stock T.O.P PHOTON , TAMIYA M05 Mini
CEFX.. High Velocity Racing Motor
Goingfast is offline   Reply With Quote
Old 04-05-2010, 08:56 AM   #870
Goingfast's Avatar
Who got the carpet set up for TA05?
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 10:20 PM
