Old 03-11-2010, 10:23 PM   #841
Skitee's Avatar
Originally Posted by Tsquare View Post
Does anyone have the parts listing to convert a TA05 IFS to a V2??
This is what you'll need to do a conversion from an IFS-R to a Ver.II
1 x 54095 - TB-03 Racing Steering Set
2 x 53851 - Titanium Coated 46mm Suspension Shaft
1 x 51253 - TB Evolution 5 "B" Parts
1 x 10115525 - TA-05 Ver.II "K" Parts
1 x 10115527 - TA-05 Ver.II "M" Parts
1 x 19115256 - TA-05 Ver.II Chassis
1 x 15405048 - TA-05 Ver.II Motor Mount
1 x 13454456 - TA-05 Ver.II Center Shaft
1 x 13454445 - TA-05 Ver.II Spur Gear Holder
1 x 54174 - TA-05 Ver.II SeperateSuspension Mounts (1C/1XC)
1 x 54172 - TA-05 Ver.II SeperateSuspension Mounts (1A/1XA)
If you want to complete the Ver.II conversion fully from a standard IFS then you'll need these parts too. It may actually be more cost effective to buy the Ver.II kit.
1 x 51092 - 46mm Swing Shaft
1 x 53742 - 46mm Swing Shaft - Lightweight
2 x 54076 - TB-03 Wheel Axles
2 x 53988 - TRF501X Ball Differential Pulley
2 x 51287 - Large Ball Diff Plate
1 x 53989 - TRF501X Center Pulley
2 x 54170 - TA-05 Ver.II Low Friction Drive Blet
2 x 53928 - Short Reversible Suspension Arm
1 x 54031 - TA05-IFS Carbon Reinforced F Parts - H Carrier (4deg)
1 x 51332 - TRF416 Front Upright
1 x 51333 - TRF416 Rear Upright
8 x 1050 bearings
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 03-12-2010, 12:44 PM   #842
Tsquare's Avatar
8 x 1050 bearings
This is perfect - thanks for the part list.
Tsquare is offline   Reply With Quote
Old 03-12-2010, 04:00 PM   #843
BigRon's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to BigRon
Default #51253
Question #1 (17.5 racers )
What gear combo are you running for 17.5 rubber? (medium indoor carpet)
Question #2 (21.5 VTA racers)
What gear combo are you running for 21.5
I'm at 96/47 for a 4.19 fdr for starters
BigRon is offline   Reply With Quote
Old 03-13-2010, 08:08 AM   #844
crydaddy's Avatar
anybody have problems fitting a thunder power battery on it's tray? also, anybody knows if there is a graphite chassis for this car?
crydaddy is offline   Reply With Quote
Old 03-13-2010, 04:31 PM   #845
Default Servo Saver
Hi guys,
Does anyone have problem with servo saver popping off?. I have a one way front diff. I have the servo saver that comes with the TA 05 V.2 package. Its a hop up part, I don't know why its popping out. I'm thinking of getting the kimbrough servo saver
fx35rc is offline   Reply With Quote
Old 03-14-2010, 08:38 AM   #846
bl4
bl4's Avatar
Does anyone know the part number for the carbon reinforced front upright thks.
bl4 is offline   Reply With Quote
Old 03-21-2010, 05:29 PM   #847
Trader Rating: 114 (100%+)
Same parts as 416x.. can be found here, along with the carbon arms, c-hubs, knuckles, etc...
http://www.tamiyausa.com/product/rcp...s&kit_id=42162
Chris Furman is offline   Reply With Quote
Old 03-21-2010, 05:31 PM   #848
Originally Posted by fx35rc View Post
Hi guys,
Servo saver only pops off if it is put together incorrectly. Looks at the instructions and illustrations again. You probably missed putting the end cap on. Never had an issue here.
Old 03-21-2010, 05:32 PM   #849
TA05v2 graphite chassis is not yet available. This car was just released, it will be coming soon, I'm sure. Any of the lipos fit, you may have to dremel the lip on one or both side of the battery tray to make it fit flat. I had to do it for one side for my Trakpower lipos.
Old 03-21-2010, 10:40 PM   #850
Thanks Chris, you were right...late night installs..I also forgot to put the end cap (K-13 part) for the belt pulley.
Old 03-24-2010, 11:02 AM   #851
CSeils's Avatar
Trader Rating: 48 (100%+)
Busted one of the H carriers (F part, 51293) last night. LHS needs to order part but looks like it might be on back order. Can I use the H carrier part from the TA05 IFS car? Any suggestions? Thanks.
You can never go wrong with a Hooters Mini. But Mini Hooters are bad.
--- USVTA National Points Series Member #122 ---
[email protected] - http://www.rctech.net/forum/painting-designs-graphics-photography/279695-usvta-trans-am-decals.html
CSeils is offline   Reply With Quote
Old 03-24-2010, 07:36 PM   #852
Super Moderator
Grizzbob's Avatar
Yes, they're the same part, actually, though I'd suggest you NOT use the carbon-filled ones, as they tend to be pretty brittle(at least from my experience they have been). And, if your local hobby shop has an easy enough time finding them, you can also use the once from the TB-EVO4(same as what's used on the more recent versions of the TRF 415, part # 51107). Keeps the geometry the same, & they're nice & chunky(& made of the more flexible plastic) so they can take a beating & keep working right....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 03-24-2010, 08:40 PM   #853
CSeils's Avatar
Part # 51107. I'll see what i can find.
Okay, what about part # 54031 for the IFS, is it the same part? I know they both are 4 hubs.
Which one would you use?
Old 03-24-2010, 09:30 PM   #854
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Carl....this depends on which IFS car you have....the Type R had different suspension from what I know..it had the light weight short reverseable suspension....the early IFS cars did not. I would look at the TB03 for what will work with your V2 as they share the same suspension and so does the 416 but the TB03 is all out of the softer plastic. All the castor blocks will work with all the suspension just the shim on the steering knuckle will or will not need to be used with some of them.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 03-25-2010, 10:09 AM   #855
tom_chang79's Avatar
I'm running a Hobbywing 17.5 (sensorless) and I'm geared at 90/47. The motor is still under-geared, it's just *slightly* warm when it comes off a 15-minute practice run!
I'm thinking of dropping the spur down to 80 and leaving the pinion at 47. I might raise the pinion to 50 if i drop the spur down to 80...
Sorry, I have no answer, I don't run that motor... Perhaps someone else can help???
RIP TAP RC
tom_chang79 is offline   Reply With Quote
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 10:20 PM
