Old 02-04-2010, 09:43 PM   #781
Skitee's Avatar
If you haven't already got the standard ver.II kit then this would be a great place to start, it has most of the popular hop ups included in the kit.
http://rss.rcmart.com/2010/01/06/tam...it-ta05v2-new/
Just add universals and your choice of aluminum suspension blocks and you're good to go.
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 02-04-2010, 10:44 PM   #782
tiko's Avatar
Trader Rating: 35 (100%+)
Send a message via Yahoo to tiko
I just got the kit and wanted to know if I should get anything else other then what came with the kit. Thanks on the suspension block info Skitee.
tiko is offline   Reply With Quote
Old 02-09-2010, 10:21 PM   #783
Akudou's Avatar
Oh boy, its been quiet here innit? 1 week since someone last posted something
Akudou is offline   Reply With Quote
Old 02-10-2010, 04:46 AM   #784
Trader Rating: 114 (100%+)
Got my 07 NSX body today.. And have my F430 painted up white with black racing stripes. And we got 8 inches of snow overnight... Yippee!
Chris Furman is offline   Reply With Quote
Old 02-11-2010, 04:30 AM   #785
Chris,
Where do you get your bodies from. Most of the US sources I know of are out of them. Looking for the Ebbro.
By the way, I ran the motor and speedo you sold me last night at practice and they work great.
Andy
woodys3b is offline   Reply With Quote
Old 02-11-2010, 04:36 AM   #786
Originally Posted by woodys3b View Post
Chris,
Andy
Good to hear!
I got the one from Speedtech RC. You can always call Trackside in WI to see if they have any... And last resort is eBay.
Sending you PM
Old 02-12-2010, 09:40 AM   #787
gearhead1962's Avatar
Hey guys i have a question. So My problem is that when coming out of a turn my car looses rear grip (on power). I am racing at a med to large (Nor Cal Hobbies) carpet track with rubber tires. Here is some of my settings
tires: T.O.P solaris softs at all corners
TRF shocks / white Tamiya springs
solid front axle
blue sway bar up front
red sway in rear
about 4.8mm ride height f&r
1 degree of toe in front rear is stock
I think I have 2 degrees of camber up front and 3 at the rear
17.5 /tekin rs
Also I have the rear shocks in the outer position on the bottom and the top i have them as far in as they can go.
Any suggestions ???
gearhead1962 is offline   Reply With Quote
Old 02-12-2010, 09:47 AM   #788
Try Tamiya short white up front and long blue in the rear and lay them down.
Oh and 0 toe.
solid front axle
red sway in rear
17.5 /tekin rs
Any suggestions ???
Old 02-12-2010, 09:58 AM   #789
94eg!'s Avatar
Trader Rating: 17 (100%+)
Also make sure your rear diff isn't too tight. I also notice your running lots of camber and front toe-in which is different from most cars I've seen. Of course I'm no pro...
94eg! is offline   Reply With Quote
Old 02-12-2010, 10:13 AM   #790
Thanks for such quick replies. The diff is already pretty loose I might be able to get a few more turn out of it though.
I will try those springs have to order them though.
As far as my camber and toe settings, I was going by the x-ray manual and some other online sources posted earlier in the tread and that is what I came up with. Also the box stock set up was super slick I found that these helped a lot with grip but I am a noober so I could be very wrong. I will try that 0 toe
Old 02-12-2010, 11:49 AM   #791
h**p://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXFAD8&P=7
are these the whites you where talking about?
are these the long ones???
h**p://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXWB01&P=7
sorry not enough posts yet to put links.
Old 02-12-2010, 11:58 AM   #792
typed below...
---- Yes, this is the short white. They also have these in a bundle called on-road short type.
---- Yes, this has the Long Blue....
Old 02-12-2010, 12:09 PM   #793
Sweet thanks I will give those a shot with the toe adj and let you guys know.
Old 02-12-2010, 12:17 PM   #794
And laydown your rear shocks. 2nd from inner most on shock tower, dope tires, full front and rear.
Old 02-12-2010, 12:33 PM   #795
This may sound noobie but "dope tires, full front and rear." I am not sure what that means.
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 10:20 PM
