Old 01-25-2010, 11:04 PM   #736
Skitee's Avatar
I don't have a picture now, check page 5 of your manual which is the diff build. The final picture shows the completed diff with the 1510 bearings being put on, before you put the bearings on the outdrives you would put the 0.1 shims on first.
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 01-25-2010, 11:07 PM   #737
Akudou's Avatar
0.1 refers to the thickness right? what about the circumference?
Akudou is offline   Reply With Quote
Old 01-25-2010, 11:19 PM   #738
Skitee's Avatar
0.1 is the thickness and it's a 10mm shim.
http://www.tamiyausa.com/product/ite...oduct-id=53588
Old 01-25-2010, 11:33 PM   #739
Akudou's Avatar
A bit confuse here but as far as i know upon installation of the Tamiya aluminium diff holders there are only 3 bearings involve. bearing 850 2 pcs and 1 thrust bearing.
Old 01-25-2010, 11:37 PM   #740
Skitee's Avatar
Not inside the diff, they go outside into the eccentric bearing holders which fit in the bulkhead.
Old 01-26-2010, 12:11 AM   #741
Akudou's Avatar
Yes i get what you mean. I think you are referring to the original plastic diff holders. The aluminium one does not use that bearing as the tensioner of the pulley is also supplied along with 53919 aluminium differential holder. Tried using the bearing on it but it will only be hanging on the outdrives
Old 01-26-2010, 05:57 PM   #742
Trader Rating: 114 (100%+)
No, he is referring to the plastic diff holders that came with the aluminum bulkhead. Please post a pic of your issue, we will try to help you out. I have the alum diff and bulkhead..
Here is the latest pic of my build. Still waiting for my last bag of Hop-ups!
Chris Furman is offline   Reply With Quote
Old 01-26-2010, 08:59 PM   #743
tom_chang79's Avatar
Chris: I really like the way you used one of those half-sized aileron servos and shoved the receiver right behind it! Nice, compact fit!
RIP TAP RC
tom_chang79 is offline   Reply With Quote
Old 01-26-2010, 11:18 PM   #744
Pingers's Avatar
My other favorite mod is heating up the antenna tube enough to bend it so you don't have to cut an additional hole in your body. Couple new pics of my practice body.
When I race GT2 TCS I'll invest in a much nicer one. This was only $10.
Pingers is offline   Reply With Quote
Old 01-27-2010, 04:55 AM   #745
Thanks... I had another 3mm of space to spare so that is where I housed the extra wire. The only thing that I do not like is that the Tekin motor weighs about 18 grams more than the LRP x12. Still thinking about switching it back to the LRP... But then again I spent all that time with the blue wire! LOL
Pingers: your ride looks great... What body are you going to get for TCS? I'm heading to trackside myself.. Will probably be running the F430... Not sure yet though.
Old 01-27-2010, 06:40 AM   #746
Pingers's Avatar
Chris: So many choices - but these are my fav;
EBBRO
Corolla Axio
ARTA Garaiya
Old 01-27-2010, 05:07 PM   #747
Hebiki's Avatar
Trader Rating: 26 (100%+)
uh oh.. did you file down your chassis?
make sure the TCS police doesnt see that.
Hebiki is offline   Reply With Quote
Old 01-27-2010, 07:40 PM   #748
Only way to make my existing lipo fit. It is only on one side and it'll be replaced with foam. I'm sure my genuine titanium screws will win them over! Hahahaha!!
Old 01-27-2010, 08:09 PM   #749
C5R01's Avatar
Send a message via Yahoo to C5R01
#9 It is strictly forbidden to cut, mill or lighten the chassis in any class. It is strictly forbidden to re-engineer or modify the car in any way other than with Tamiya Hop-Ups. (This applies to all classes
Current Cars:
Tamiya Garage:TB03; TA05V2-IFS; 414X #60;F104 V2;TA03r-s:TA03F:TA03R: FF01: FF03: M01: M03: M06: 1/14 Mercedes Semi truck- w/Reefer trailer ( fully functional): Tamiya Juggernaut 4X4X4, Tamiya RC Freightliner Cascadia Evo.; Honda City Turbo WR-02C; TRF102 F1
OTHERS:Kyosho 1/8th scale nitro Corvette C6R: Yokomo GT4 nitro, Slash 2WD,TA SCm5
C5R01 is offline   Reply With Quote
Old 01-27-2010, 08:10 PM   #750
Akudou's Avatar
Skitee, found whats wrong with the slight play, problem solved. Thanks.
Electric Touring / On-Road RC Screaming Wind Manila Racers 32165 10-24-2016 09:33 PM
