Old 01-23-2010, 09:22 PM   #721
Trader Rating: 114 (100%+)
Originally Posted by 94eg! View Post
All the money you spent on the bulkheads and motor mount, you could have had a 416. And you wouldn't have to hack up an expensive servo...
Haha.. the grand total with the hop-ups.. I could have had TWO 416x kits!
But.. I LOVE the tub chassis and the TA05... and I can run the GT2 class.. and I personally think it looks better!
Chris Furman is offline   Reply With Quote
Old 01-23-2010, 09:37 PM   #722
tom_chang79's Avatar
Originally Posted by Chris Furman View Post
Alright.. this is how far I am until the rest of my Hop-Ups come in from Japan! And that LRP SXX Stock Spec should be in next week too!
ah.... so happy...
Pimp. Just pure pimp ride...
RIP TAP RC
tom_chang79 is offline   Reply With Quote
Old 01-23-2010, 11:14 PM   #723
zangonli's Avatar
Is anyone driving their ta05 with a front one-way? It's in the ta05 v.2 upgrade pack kit which I am eyeing closely.
zangonli is offline   Reply With Quote
Old 01-24-2010, 04:30 PM   #724
Akudou's Avatar
I had the front and rear aluminium diff holders on tamiya installed a couple of months ago and theres this lil plastic c thing that goes on the dogbone so as to protect the diff outdrives but however i ran out of the plastic C and am looking for another option as i dont find it anywhere at the LHS.
Akudou is offline   Reply With Quote
Old 01-24-2010, 05:09 PM   #725
Default Direct Drive - Steering Vibration
Hi there,
Am having a problem with my v2, and hope you guys can shed some light..
I am having a steering vibration (only when wheels are either pointing left or right) when throttle is up to about 3/4... with the direct drive (front spool).
When I had the diffs or the front one-way, there was no such problem.
I have the universal shafts on my car.
when i took the wheels off and tested it again, there was no noticeable vibration!! put the wheels back on, and there it (vibration) was. 'Rotated' wheels (front and back)... same problem.
Again, the problem is there with the direct drive and wheels pointing either left or right... when the wheels are pointing str8, no vibration.
Hope u guys can help
thanks
sammies is offline   Reply With Quote
Old 01-24-2010, 05:14 PM   #726
Too much binding... Either you have WAY too much steering... Or your CV joints need maintenance.
Old 01-24-2010, 06:13 PM   #727
Hi Chris,
thanks for the quick reply... but...
a. wheels pointing either left or right does not refer to full-lock... i estimate it to anywhere between 10% to 100% of steering.
b. the direct spool is new.. so the outdrives are new.. my universals are new too.. got them both on Friday..
Do you have any other thoughts on the matter? I've tried everything i could think of..
Old 01-24-2010, 11:56 PM   #728
Originally Posted by sammies View Post
Hi Chris,
I was desperately searching the net for a solution... I chanced upon another forum where someone was having a similar problem with a TB03.
The solution was to use a shorter shaft... apparently, the TB03 manual recommends a 44mm or 42mm shaft.
What does the length of the shaft have to do with the vibrations experienced? Do u guys think that this is a possible solution?
Old 01-25-2010, 12:00 AM   #729
Tpg racer's Avatar
Posting on behalf of a friend of mine, any ideas how to mount twin cooling fans for the motor? I personally do not own a TA05 chassis and therefore appreciates any ideas on this matter... The more the merrier as the saying goes...
Oh and it would be best with pictures for examples too...
Tpg racer is offline   Reply With Quote
Old 01-25-2010, 06:28 PM   #730
zangonli's Avatar
I use the R1 Wurks dual fan strap:
http://shop.r1wurks.com/index.php?ma...128b4e437add5b
Sorry don't have any pics, but to get this strap to fit properly around the motor in my ta05 (original version, not the v.2), I ground down the chassis about a 1mm underneath the motor where you will be locating the strap, so that the motor is not forced off axis... clear?
Old 01-25-2010, 08:55 PM   #731
Pingers's Avatar
Chris your attitude is awesome man!
I'm really tired of guys coming in here to flame us about what we could or should have bought. If I wanted a 416 I assure you I would have bought one.
Kudos to you and your ride Chris - I love it.
Pingers is offline   Reply With Quote
Old 01-25-2010, 09:30 PM   #732
+1
RIP TAP RC
Old 01-25-2010, 10:16 PM   #733
Akudou's Avatar
After installing the aluminium diff holder, i realise there is a slight play from left to right and these applies on the front and rear as well. Anyone have the same problem ?
Old 01-25-2010, 10:23 PM   #734
Skitee's Avatar
Yes I also had that, you just need to put 2 x 0.1 shims between the 1510 bearing and the diff outdrive and the play should be gone.
Xray T4 2017 ~ ORCA Vritra VX3 ~ Motiv RC 4.5
Xray T4 2017 ~ ORCA Vritra VX3 ~ R1 Wurks 13.5
Xray X12 2016 ~ ORCA Vritra VX3 ~ Orca TX 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 01-25-2010, 10:36 PM   #735
Akudou's Avatar
Do you have a pic so i can see it more in detail?
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 10:20 PM
